#37 |
Honda Convert
Drives: NCP91L Join Date: Sep 2006
Do you guys think that 205/45/16 would rub, with most moderate lowering springs?
#38 |
ringmeister
Drives: YARIS 1.5 Join Date: Mar 2007
From what I gather, so long as you have the correct offset... for a 6.5" wheel its +40 for a 7" wheel +45, it shldnt rub at all.
Right ? |
#39 |
Rwseattle
Drives: 2007 Toyota Yaris (BASE) Join Date: Dec 2006
No rub
Hey, dresden_k
I drive on 205/45/16 with Tanabe NF210. No rub. Zero problems. I will post new pictures this week so you can check out the lowering situation. I need to clean the outside before posting new pix. Its drives great. I do still need a alignment but that will happen this Saturday. I personally believe that you should always do the alignment after removing the springs. Rwseattle. |
#40 |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
#41 |
hey large ur yaris looks good thinking about getting the spring techs myslef i love the drop. I was just wondering if you had 195's instead of 205's will it still rub in dips and all
#42 |
My 6.5" +40 with 195 juuuuuuust graze (you can just see road dust being rubbed) on full bumpstop mashing compresion with the wheels turned, though no damage at all. I just mounted some 7" +40 with 205/50 Toyo RA1's and unfortunatly they are tearing my front wheelwells apart and scuffing the tires pretty bad if the wheel is turned and the front end loads up hard. Drop is Tein S.Tech's with cut bumpstops/stock struts. I'm bummed because I was hoping I could get away with the wheels, but it looks like I'll need +45 and removing that area of wheel well liner to clear it 7" wide rims.
Good luck. |
#43 |
really dam the s techs drop the yari really low i guess but thanks for the info
#44 |
Mind you that's only worst-case-scenario: shocks mashed flat, tires cut hard, no camber adjustments (as 03Z33 has had success running his car hard with +35's, but camber cranked allowing the wheel/tire to slip inside the wheelwells and clear). I hope you find something that works for you.
I'll try and get some +42, 43 and 45's in 7" to test fit soon and let you know how it goes. |
#45 |
thanks man i appreceiate the feedback!!!what off set would you recommed for a daily driver is 40 plus ok with 16x7's and how low of a drop is 1.7 ok?
| New 07 Yaris S need advice on 18's and springs | OgDogg | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 48 | 04-27-2009 10:50 PM |
| Got new wheels, tires, and springs installed. | largeorangefont | Photo-Video-Media Gallery | 8 | 01-22-2007 05:29 PM |
| Just put my new wheels on | Ryosuke | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 07-18-2006 02:04 AM |
| Lets talk wheels | birdy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 80 | 04-29-2006 02:13 AM |
