Thailand OEM/Aftermarket Group Buy Round 3!
I sure kept you guys waiting and I'm sorry for that, but here we go!
This is how it's gonna work, for the most part it will be just like the first round, so please take a look again: http://www.yarisworld.com/forums/showthread.php?t=5142 OEM Toyota Accessories ![]() ![]() ![]() And for the sedan: ![]() Many of the LB's interior accessories should also fit the sedan. There's actual photos of most of these items here: http://www.yarisworld.com/forums/sho...&postcount=227 Aftermarket Accessories LED side mirrors: ![]() ![]() ![]() (thanks to Violin for the animation pic) $125 per pair WARNING!!! There is a slight difference between the USDM side mirrors and these, they will not be a direct replacement, some modification is needed. Here are instructions: http://www.yarisworld.com/forums/sho...?t=6447&page=2 These are pre-painted, but only in our locally available colors, so here's a matching guide: ![]() The paint codes in BOLD are an exact match, and I've put what would be the closest match for some other colors. The closest match colors may look good, they may look mis-matched, there's no way to know right now. If you have one of those mis-matched colors, you should try to get the closest one, and if it does not look good, I guess your best choice would be to have them re-painted locally. Or, if you also get a bodykit and choose to have it painted, they can probably also re-paint these to match. Replica Modelista-style JDM LED lights: US$180 per pair Black Tinted "Altezza" LED lights: US$190 per pair Replica Netz (lightning)Logos for front and back ![]() $35 (front) $25 (back) Replica Vitz and RS badges ![]() $15 (Vitz) $35 (RS) And some pictures of the actual items: http://www.yarisworld.com/forums/sho...&postcount=214 Performance Parts Nitto Exhausts These are available in three flavors: Header-back (i.e. midpipes+axleback) - $320 Axle-back only - $150 Midpipe only - $250 The axleback is of a design similar to the HKS unit: ![]() There is also a version adapted to the Vios (Yaris sedan) And the mid-pipe is a two piece affair: ![]() For more information, please check this thread: http://www.yarisworld.com/forums/showthread.php?t=9047 Nitto Strut Bars A good alternative to those big-name brands! Front strut bar - $100 ![]() Rear strut bar - $100 ![]() Bottom bar (warning, this is NOT a sway bar, and I am not sure if it can be used if you already have a sway bar there) - $160 ![]() Engine torque damper - $160 ![]() Rear Disc Brake Conversion kit No pictures yet, but this is a kit to change rear drums to 240mm (9.5") disc brakes, with 2-pot calipers. It requires no modification of your actual car, so can be swapped back with the stock drums if ever needed. The price is $880 for the kit. Replica Bodykits *Please Read This!* As mentioned in another thread, these FRP replica bodykits can be obtained in two grades. Grade A is almost as good as the original JDM kits and should be able to fit with minimal headache. We will not be offering the Grade B kits this time. For people in North America, please keep in mind that fitting these will require you to remove the rear bumper brace, and quite possibly the front one too, as your bumpers are quite a bit deeper than ours. If needed, painting can be arranged (but is not recommended as it may possibly scratch during shipping), at an extra cost of $500 for a full kit. This will be done with Dupont 2K paint, and we will require you to send us the tow hook cover from your front bumper (that little round plug), so that the shop can get the best possible paint match. C-ONE Style: ![]() ![]() Grade A: $1200 unpainted, 5 piece kit (front bumper, rear RS bumper, rear skirt, side skirts, spoiler) Ings+1 Style: ![]() ![]() Grade A: $1200 unpainted, 4 piece kit (front bumper, rear bumper, side skirts, C-ONE style spoiler) Burnout KD-VII Style: ![]() ![]() Grade A: $1300 unpainted, 6 piece kit (front bumper, rear RS bumper, rear corner skirts, side skirts, C-ONE style spoiler, eyelids) Pricing breakdown for individual pieces Let's say you only want a C-ONE front bumper, or you want to mix and match different styles/grades... GRADE A: C-ONE/Ings+1/Burnout Front bumper + mesh: $450 RS Front Bumper + Grille + Fog lights + Netz badge: $700 RS or Ings+1 Rear Bumper + Fog lights + licence plate lights: $600 Side Skirts (per pair): $320 C-ONE/Burnout Rear skirt: $160 RS/C-ONE Roof Spoiler: $160 Burnout eyelids: $100 ------------------------------------------------------- The fine print: Estimated shipping prices for one bodykit would be $800 by air freight, or $500 by sea freight. You would be responsible for any customs charges, though, but we can undervalue the invoice to keep this to a minimum. Also, there may be additional fees for delivery from the port in your country to your door. Please understand that you would be buying these at your own risk, any painting, fitting, and installation are at your own expense. I will inspect each piece before shipping to verify there is no damage, but once they are shipped, that will be out of my control. At the moment we are unable to confirm whether side skirts will fit correctly on 3-door models. It is most likely some modification of the skirt (grinding away of material or fabrication of a bracket) is needed. --------------------------------------------------------- How to order Just PM me and let me know which items you are interested in buying, and I will get back to you with a quotation including estimated shipping price. If that is acceptable, then let me know and a Paypal invoice will be sent to you. I'll set the ordering deadline for the 15th of October, so there is plenty of time to get things organized ![]() All right then! Let's do this!
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... Last edited by eTiMaGo; 09-23-2007 at 09:26 PM. |
| NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) | NonStopTuning | NonStopTuning | 266 | 09-29-2007 02:51 AM |
| MEGAN HEADERS! < group buy price! | C2AUTOSPL | Sponsors Classifieds Area | 20 | 09-17-2007 01:54 PM |
| GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... | riceboy | Items for Sale by private party | 453 | 07-14-2007 08:30 AM |
| KLight HID Conversion Group Buy!! $165.00 shipped!! | JRT lighting | Sponsors Classifieds Area | 4 | 11-20-2006 10:47 PM |
| Intake group buy? | Lowfront | Items for Sale by private party | 20 | 11-17-2006 04:45 PM |
