Old 07-23-2006, 01:41 PM   #19
heylookitsjames
maintenance of momentum
Drives: 2007 5spd 3dr
Originally Posted by Chaad32
That is still too much for disk brakes. Will the disks in the rear really help??
Not as much as you are hoping. But it looks better.
heylookitsjames is offline   Reply With Quote
Old 07-23-2006, 04:12 PM   #20
eight_heads
eight_heads's Avatar
Drives: '07 Yaris Liftback
well i'll put it this way... i've had 3 honda crx's through the years and one set came with disc front/drums rear and one came with disc on both... now the disc on both were supposed to be better...i did a little testing near a private airport nearby with both cars and they were very close(the one with disc in front/rear was a little better)... then i switched out the proportioning valve in the one with drums in the back with that from an integra(no other brake mods) and the one with drums in the back was ALOT better than the one with dual disc.... we may be able to do something like that with the yaris
'07 Yaris Liftback
-Red 5spd w/convenience
eight_heads is offline   Reply With Quote
Old 07-23-2006, 07:34 PM   #21
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Originally Posted by eight_heads
wthen i switched out the proportioning valve in the one with drums in the back with that from an integra(no other brake mods) and the one with drums in the back was ALOT better than the one with dual disc.... we may be able to do something like that with the yaris
Keep me posted!!
Old 07-23-2006, 09:23 PM   #22
eight_heads
now anyone with abs it may cause a problem with something like that, but when i get a chance i will look at and do some investigating on the proportioning valve and brake setups on our cars
'07 Yaris Liftback
Old 07-25-2006, 08:27 PM   #23
soros151
Another question... :D
soros151's Avatar
Drives: Scion tC 06
Please do!
*One tire nearer to my goal*
soros151 is offline   Reply With Quote
