Old 09-25-2007, 03:36 AM   #1
drecian
drecian's Avatar
Drives: '07 YR 3dr
Depends on how tight the turn is and how you drive. On hairpins, the fastest I can usually get around them is aounrd 40mph/60kph exit speeds, of course lower if the radius is smaller. On 90*/rightangled corners, gripping; I can usually hit them at 45mph/70kph before I understeer wide. HOWEVER, if you throw the car into a slide so that you have completed *most* of the rotation for the corner by the apex, you will less understeer-related problems. With this method, exit speeds ride to about 50mph/80kph. Note that is is not drift with crazy slip angles, and if you are using little/any opposite lock countersteer, you are loosing speed as your are trying to 'recover' the slide. Think more rally technique rather than drift. Those who have driven/played on dirt know that to drive a car fast in low traction situations require a different technique to overcome understeer, usually by rotating the car before the apex to reduce the steering input on exit and allowing to power out without running excessively wide. Well; once you reach the grip threshold of your tires, it becomes a low traction situation, just like drivingon dirt, but at much higher speeds...
Remember, the track's the only safe place to experiment...
"I drive a silver egg"
"Huh?"
"An egg... You know; pretty much round, but with a pointy end; jeez..."
drecian is offline   Reply With Quote
What is the most economic speed for Yaris? hans_fh General Yaris / Vitz Discussion 18 02-18-2007 04:34 AM
New Yaris Owner Kiteless General Yaris / Vitz Discussion 8 08-02-2006 11:48 PM
