#73 |
I want JDM bumpers!
Drives: 5 Dr Yaris RS in Blazing Blue Join Date: Feb 2006
It's on hold until I find out how to get the circuit working. hahaha!
Trying to get the fog light to become DRL, with on/off switch still function. My friend did that to his Civic SiR, so need to find time so we can sit down and look at it. And thanks for following up, I will definitely post up some info once I get it done. |
#74 |
Well, If i understand the DRL circuitry correctly, it's an independent wire that hooks to the headlamps power. So, in theory, you can re route the DRL power to the foglights. My Yaris doesn't have neither DRL nor Foglights, so I can't vouch for this to work. In theory, however, if you can find where the DRL circuit hooks up to the headlamp harness, you can just cut this connection and connect it to the foglights one instead.
#75 |
I want JDM bumpers!
I think it's the other way, as there is only one wire going to the bulb, which is a H4 bulb, and it is the DRL module that regulates how much power to go to the bulb, i.e. DRL or Low Beam. So I cannot just hook this wire to the fog to make it DRL, else I will lose the Low Beam wire. This is how I understand the circuit diagram from the DIY section.
| Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) | gaffo | General Yaris / Vitz Discussion | 28 | 07-15-2007 07:55 PM |
| Southeastern Power Package with Alloy wheels? | Where is my Yaris? | New YARIS Purchase Forum | 0 | 03-23-2007 07:40 AM |
| convenience vs. power package | jeff_o | General Yaris / Vitz Discussion | 25 | 10-17-2006 10:04 AM |
| Is concenience package and power package the same thing on liftback ? | YarisBlazer | General Yaris / Vitz Discussion | 4 | 07-21-2006 11:58 PM |
| Waiting for the Taiwan Yaris | heybai | General Yaris / Vitz Discussion | 13 | 03-12-2006 07:26 AM |
