Old 09-28-2007, 04:56 PM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
I've done that. 89 Octane = a loss of 5% MPG, 93 Octane = a 9% loss.
I tried 2 tanks in a row of each to get a more accurate test (and the low numbers hurt my running tank average). Without a doubt I consistently get the highest MPG with 87 Octane.
Aside from my much calmer driving style two other things that may make a difference for me are that we're always on 10% Ethanol here and I'm at a higher altitude than most folks (my home is at 4,500ft., my office is a 6,350ft., and I traverse an 8,900ft. summit to get there).
- Brian
Share the Road
Old 09-28-2007, 05:10 PM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
facinating...i just filled up with my first tank of 91...have been running 89 and it appears as though to start i'm getting a bit better mpg with the 91 than i have with the few tanks of 89...as far as conditions go, i'm in socal and its been warm (besides today lol)...trying to figure out what would be the best octane to run for engine life vs. FE...87, 89 or 91...
Old 09-28-2007, 08:44 PM   #3
voodoo22
Drives: Yaris Sedan (auto)
Do you have Shell gas around there which put 0% ethanol in their V-power? I wonder how that would result. I can't see you gaining over 9% based on no ethanol. I only use regular and can't justify spening over 10% more for gas when the car doesn't need it. After years of buying premium, spending less than $30 on gas at the end of the week is something I don't want to give up
voodoo22 is offline   Reply With Quote
Old 09-28-2007, 10:24 PM   #4
BailOut
BailOut's Avatar
I only use Shell gas and E10 is a mandate. Regardless of the Octane level, if you buy it in Nevada or California it's 10% Ethanol. In the cold months it gets worse as our Winter fuel - by mandate - is E10 RFG (reformulated gasoline).
This helps the lead-footers produce much less emissions, which is a good thing, but by proxy it robs the proper drivers of lots of mileage.
- Brian
Share the Road
