#1 | |
Your Toyota Technician
because they can shift, theres enough space to make a bit of noise. i have used brake lube on the shims and inserts on highlanders, corolla's, tc's, camry's, avalons, rav4's...and so on from this complaint. |
Spool'd
Drives: 07 yaris, 16 gen coupe rspec Join Date: Aug 2007
Our Saturn used to do that too. It is the brake pads, don't worry about the noise at all. The brake pads have to move inside the caliper, otherwise how would the brakes work. Sometimes there is just more room for play, but the pads will never come out or fall out of place in any way. You're perfectly fine.
![]() Drives: 2008 Yaris sedan 5 speed Join Date: Mar 2007
[QUOTE=Toyotech;146150]because they can shift, theres enough space to make a bit of noise. i have used brake lube on the shims and inserts on highlanders, corolla's, tc's, camry's, avalons, rav4's...and so on from this complaint.[/QUOTE
Would the brake lube be included on a brake cleaning/adjustment at the dealer? |
#4 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
but thats just me talking from 'flat rate' experience |
Thanks for the replies. I will have them look at it next time I'm in. I've been changing my own oil since the first two changes. Was wondering if I missed anything in all the lost post about this.
| noise while backing up | jonr0613 | General Yaris / Vitz Discussion | 31 | 09-08-2007 06:23 AM |
| Air Conditioner Noise | Cathy | General Yaris / Vitz Discussion | 16 | 05-08-2007 02:08 AM |
| 2007 LB Auto-Trans NOISE in Reverse | Pavel Olavich | General Yaris / Vitz Discussion | 4 | 03-22-2007 07:42 PM |
| long time lurker, first time poster | tekmoe | New YARIS Purchase Forum | 1 | 10-04-2006 12:43 AM |
