Old 09-29-2007, 06:10 PM   #1
dougb
Drives: 2007 yaris sedan
RIM FIT
Will a honda rim fit a Yaris? What about other rims that will fit? THANKS
dougb is offline   Reply With Quote
Old 09-29-2007, 06:17 PM   #2
contraband831
El Huevo
contraband831's Avatar
Drives: 2007 Liftback
if it is 4x100
what year?
what model?
Old 09-29-2007, 06:34 PM   #3
yes, it has to have a lug pattern of 4x100. they also have to be within a range for the offset. not sure, but i think the stock offset is +38 or +40. i would go no less than +38 because you might have rubbing issues (especially if you're lowered).
Old 09-29-2007, 06:34 PM   #4
dougb
rims
I was just wondering what other stock rims would fit on Yaris.
Old 09-29-2007, 06:37 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
Just about any 4x100 FWD rims will fit. Stock FWD offset is generally between +40mm and +50mm, so you should be okay.
Old 09-29-2007, 06:38 PM   #6
contraband831
El Huevo
mini cooper, 93-97 corolla, older civics, and i am sure there are plenty more
Old 09-29-2007, 06:40 PM   #7
if you have other OEM rims, go for it, but if you're planning on buying some, you should rather save up and buy a nice, used set of aftermarket rims (meeting those "requirements").
i'm not sure of other OEM offsets, but if Kimona is right, then, like he said, you should be fine.
Old 09-29-2007, 06:43 PM   #8
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Be careful with four-lug Honda rims because some are 4x114, too. As long as it's for a Civic or pre 1989 Accord it'll fit.
Old 09-30-2007, 03:15 PM   #9
dougb
Thank you all very much you have been a great help.
Old 09-30-2007, 04:53 PM   #10
no problemo.
Old 09-30-2007, 08:24 PM   #11
Lafiro
Drives: 06 Yaris Sedan
I wouldnt want rims from pre-1989......
How closely have you looked at other cars like the Fit or Versa? grampi General Yaris / Vitz Discussion 30 09-08-2010 08:29 PM
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd Bounty Hunter General Yaris / Vitz Discussion 7 07-11-2007 07:40 AM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
Will S Sedan Alloys Fit on A Liftback? MrMondayNite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 11-05-2006 01:39 PM
