Old 02-28-2010, 12:33 PM   #1
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by PhilD424 View Post
Damn 5W20? Thats wayyy to thin. Even so with 5W30. I personally wouldn't use anything less then 10W30, atleast for the kind of driving we do in NYC.
5w30 is considerably thicker at 0F than it is at 200F. Just not by as much as a straight weight oil. Why do you think that it needs to be *even thicker* when cold, but don't seem concerned about 5w30 at normal operating temperature. In practice, the lower the first number the better. It's the second number that is really significant. Personally, I don't see the point in 10w30. It just takes longer to flow and makes the car harder to start in cold weather.
At any rate, Toyota says 5w30. Some engines, Yaris' included, use the engine oil as hydraulic fluid to do certain things. (Yaris' vvt-i engine uses it to control the valve timing.) So messing around with non-spec viscosities *can* have unintended consequences.
Use what the filler cap recommends.
sbergman27 is offline   Reply With Quote
Old 03-02-2010, 02:29 PM   #2
Hard_Yaris
Drives: 07 Yaris
I want to know what the Deal is with the FRAM oil filters? Problems or just a personal preference?
Hard_Yaris is offline   Reply With Quote
Old 03-02-2010, 08:29 PM   #3
Happy Little Pony
Drives: 2007 Yaris HB
If I may be so bold as to offer my opinion:
The cheapest Fram filters (the "orange can") have gotten a bad reputation. It may be deserved or it may not. There are plenty of anecdotal stories of Frams letting people down, but anecdotes are not proof that Fram's are any more prone to failure than any other cheapie brand. The main point of contention seems to surround the use of paper-like fiber end caps on the filter element instead of something more substantial (like, you know, METAL!). The more expensive Fram models seem to be made a little more stout and you don't hear as many complaints about them.
I've used Frams in the past, there are millions of cars on the road using them now, and, if I couldn't obtain anything else, I wouldn't have a problem using one today. But they are way down on my list.
From Amazon, I can get Purolator Pure One's for about $4.75 or Denso for $3.94. Better filters for about the same price.
Happy Little Pony is offline   Reply With Quote
Old 09-06-2009, 11:22 AM   #4
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Nice write up! This needs to be a sticky.
Just FYI prefilling filters (or not) is one of those eternal polarizing arguements-I'm not even going to go there just be clean about it!
Anything in the center tube is heading for the bearings unfiltered so don't let any crud in there.
65mm 14 flute cap style filter wrench on a 3/8 ratchet works great for the Yaris.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 09-06-2009, 01:43 PM   #5
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I've never prefilled filters. Never saw anybody else do it, either, only certain somewhat OC people who've written online instructions. It just takes a few seconds for the oil pump to fill it and the gauge pressure comes right up. The residual lubrication in the engine that was just shut down carries it through that.
Old 09-06-2009, 02:45 PM   #6
RedRide
RedRide's Avatar
Yes. Most service depts and local garages do not prefill a filter.
While it is a good thing to do no harm will come to an engine if you don't.
As Yaris Hilton said, it only takes a couple of seconds for it to fill and oil pressur to build up.
Just don't redline it the second you start it and it will be fine.
Old 08-12-2011, 10:56 PM   #7
TXyaris
Drives: Currently stock '09 Sedan.
damn.. thats what i always do! lol
TXyaris is offline   Reply With Quote
Old 07-18-2012, 08:33 PM   #8
biggyjiggy
Drives: 07 Red Yaris LB
just did my first oil change on my yaris :) since ive had it. Thank you very much for the write up it helped alot :)
biggyjiggy is offline   Reply With Quote
Old 09-06-2009, 02:56 PM   #9
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I would recommend against using a band filter clamp there is almost no room for that. I would recommend cap style as R2D2 said above.
Old 09-08-2009, 10:16 AM   #10
bronsin
bronsin's Avatar
If you turn the oil filter in the direction you indicate in your illustration to loosen it you will tighten it instead.
Old 10-08-2009, 11:27 AM   #11
yarisitis
yarisitis's Avatar
Drives: 2008 Yaris LB
I'm going to be doing an oil change on my Yaris today or tomorrow and I want to get something clear before, kinda dumb question...
The drain plug is the one circled in red right?
Better safe than sorry.
yarisitis is offline   Reply With Quote
Old 10-08-2009, 12:46 PM   #12
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
^^ Yes.
Old 10-08-2009, 01:37 PM   #13
bronsin
bronsin's Avatar
Excellent!
Old 10-08-2009, 03:43 PM   #14
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
FYI, don't qoute me..., but If I remember correctly my Amsoil monthly info a couple months ago said something about Toyota going either 0w20, or 5w20 recommended in 2010 or 2011 cars. Evedently for better mileage. I'll try to find the info.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 10-11-2009, 07:33 PM   #15
yarisitis
yarisitis's Avatar
Oops, I put in too much oil than I should have...I think, reading the damn dipstick, as easy as it sounds, is a pain because one side has the oil at the full level and the other side has it way above the full level. It's pretty misleading so I don't know if I over filled it or not.
Are there any real consequences (drop in MPG, bad for the engine?) from this or will it be fine?
It should be fine as long as I don't get any checking engine lights or oil pressure lights coming on right?
Old 10-12-2009, 12:49 AM   #16
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Still within the dots but towards the higher end? Can you take a pic?
Old 10-12-2009, 01:48 AM   #17
yarisitis
yarisitis's Avatar
On one side it's all the way to the dot marking full, and on the other side it's way beyond the full dot.
I'll try taking a picture tomorrow so you can actually see.
Old 10-11-2009, 11:40 PM   #18
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Install a Fumoto valve in the drain hole, then oil changing is easier and if you over fill, you can drain a little to the correct level.
Yaris oil change appreciation flagmunkey DIY / Maintenance / Service 18 07-19-2007 03:46 PM
first oil change? wushumasterku DIY / Maintenance / Service 41 06-07-2006 10:32 AM
