Old 10-19-2008, 10:23 PM   #1
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
Another reason to buy a torque damper for the engine.
eco is offline   Reply With Quote
Old 10-20-2008, 05:33 PM   #2
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Yoda is offline   Reply With Quote
Old 10-21-2008, 06:35 PM   #3
Split
Drives: 2008 Yaris Sedan
Question
Originally Posted by Malaya1221 View Post
yes, it's split in half by the o2 sensor!
calling WEAPON R....i need warranty on this!
hey garm, still thinking about the DC header that you got.....might just install the oem header!
can we get a video clip of this thing at WOT from inside the car?
Split is offline   Reply With Quote
Old 10-21-2008, 06:41 PM   #4
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
^ IT IS LOUD!
if u close ur eyes u wouldn't believe it's the yaris!
on idle, bog bog bog bog!
Old 10-21-2008, 10:43 PM   #5
White Yaris
Broke Tuner
White Yaris's Avatar
Drives: White Yaris
that sucks... Hey you had fun with it right?
White Yaris is offline   Reply With Quote
Old 10-21-2008, 11:06 PM   #6
Malaya1221
Malaya1221's Avatar
^ absolutely! i like the 4-2-1 type header but the weld on the o2 sensor where it broke had rust on them...IMO, the weld on the last tube was not primo!
got me a dc header (4-1) from garm for a very reasonable price!
Old 11-15-2008, 11:26 PM   #7
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
I have thought about this over the last few weeks and I have the answer to why this happened. There is a flaw in Weapons design of the header that Megan and Toyota didn't have. Do you remember the side bolt that was on the bottom of the stock exhaust? That is for this very sort of occurence. It prevents the exhaust from rattling around and reduces vibrations. This is why I haven't had a problem with my megan. Other people who have other headers maybe even the Weapon itself might not have the same issue as you did. But not having that extra anchoring point is likely the culprit.
ztrack157 is offline   Reply With Quote
Old 11-16-2008, 12:15 AM   #8
kou
Drives: 08 lb
read the entire thread the reason has already been found.
Old 11-16-2008, 12:23 AM   #9
ztrack157
ztrack157's Avatar
Just because your theory on what happened is accepted doesn't mean it was the only factor. I'm just offering more into what caused the malfunction. Theres a bunch of things wrong with this set up.
Old 11-16-2008, 12:31 AM   #10
kou
Drives: 08 lb
how, it bolts on the same way.if you dont put the springs back on the bolts like it is stock any header will snap with fatigue.
Old 11-16-2008, 01:05 AM   #11
Malaya1221
Malaya1221's Avatar
no need to argue boys, weapon r gave me a warranty on this!
yup, only weapon r header doesn't have a side bolt!
Old 11-16-2008, 01:21 AM   #12
kou
Drives: 08 lb
nice of them to do that.
Old 11-16-2008, 01:30 AM   #13
Malaya1221
Malaya1221's Avatar
yup, they decided it was their fault and i'm one happy customer!
Old 11-17-2008, 03:38 PM   #14
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
wow, that's awesome customer support coming from weapon r... good for them.
id3379 is offline   Reply With Quote
Old 11-16-2008, 01:03 PM   #15
bobobitch
bobobitch's Avatar
Drives: Yaris HB
Send a message via AIM to bobobitch Send a message via MSN to bobobitch Send a message via Yahoo to bobobitch
so do you know if weapon r is going to fix that problem?
bobobitch is offline   Reply With Quote
Old 11-16-2008, 01:55 PM   #16
ztrack157
ztrack157's Avatar
They should for future models.
Old 11-16-2008, 03:44 PM   #17
kou
Drives: 08 lb
i suppose it could be a problem but i have had know issues for 2 years and 2 cars. the point is you need the springs, they have to be there..
Old 11-16-2008, 04:40 PM   #18
Malaya1221
Malaya1221's Avatar
imo, kou has a point here in installing the spring bolt because it would help lessen the vibration but, to say that's the answer to the problem w/o knowing all the factors would be foolish...
i think we should ask someone who has the nitto mid-pipe and weapon r header installed in their car and give us their opinions about it because mine did not fit snugly while installing it with the oem spring bolt!
i think weapon r header has it only for less than 2 yrs so i wouldn't know where kou got his 2 headers!...
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
Are We Still Stuck With the 4-1 Headers? Sabretooth Performance Modifications 31 02-20-2009 08:57 PM
DC sports header installed. largeorangefont Performance Modifications 41 09-20-2007 09:14 PM
Weapon-R Header (4-2-1) CASTREX Performance Modifications 28 02-19-2007 01:57 PM
Who got that weapon header? Galavoxx Performance Modifications 1 12-04-2006 09:11 PM
