![]() ![]() ![]() Drives: 2011 Yaris RS 5 door 5 spd Join Date: Aug 2012
[EDIT] whoops, cross post
1. jack up the front of the car, remove front wheels. 2. Remove fender liner (OR separate enough so you can reach up underneath 3. Install left and right brackets (black ones). Two people is way easier so you can get to the top of the bolt and the nut underneath, but I have done this alone before. 4. Adjust threaded end pieces to line up with bracket holes. 5. Install bar to the brackets. 6. Tighten everything, put wheels on, lower car. DONE. Did I miss anything?
Nope you got everything. I would suggest to just inspect the install after driving the car around a bit to make sure everything is still tight and secure.
| Installed the Tanabe Strut bar but had to remove my ground wire kit.. | vacantj | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-01-2007 01:56 PM |
| **NEW ITEM** Tanabe Sustec Front strut bars | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 04-27-2007 09:54 PM |
