Stoln they come in blue and white, I only got blue this time.
From the picture above I can tell you how to wire your ignition light. Pull the dome light connector Donnie has pointed to. It's a 6 pin connector. You need to splice your black ground wire to the pink wire which is off of pin 2, and splice your red power cable to the blue wire which is off of pin 5.
When it is wired here, your ignition light will come on when you open your car door. It will then shut off with the dome light when it times out or when you start your car. When you shut your car off, the ignition light comes on, then times off with the dome light. This is where I wired mine. As for the physical installation of the light. It's preety easy. Just remove the two phillips head screws behind the steering wheel. There's one on the left and one on the right. You'll need to spin the steering wheel to get to each screw. Pop the plastic covers loose. I dremmeled the opening around the ignition switch slightly on both the bottom and top covers. This helped the fit once the plastic light is placed around the ignition switch. I also put a small black shroud around my light so it would reduce the bleed of the light inside the column, through the side column seams. I hope this helped. Sorry I don't have any pictures. I installed mine two weeks ago based on a previous DIY. |
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
The poison in your poison
Drives: 2008 Black Liftback MT Join Date: Oct 2008
| Bulb Replacement Guide (led Sizes) | theFEVA | Cosmetic Modifications (Exterior/Interior) | 113 | 02-28-2017 12:02 PM |
| LED Tag Light? | Kaeon | Cosmetic Modifications (Exterior/Interior) | 10 | 08-09-2010 01:42 AM |
| 12 LED Dome Light Festoon | bigsky2 | Cosmetic Modifications (Exterior/Interior) | 26 | 04-18-2010 10:38 AM |
| LED tail light question | Julz | Cosmetic Modifications (Exterior/Interior) | 4 | 06-19-2009 09:25 AM |
