#1 | ||
![]() ![]() Drives: 09 Yaris hatch, 09 Z51 'Vette Join Date: Oct 2008
The owner's manual says 59 MPH can be achieved in 2nd gear, while you say 44 MPH... And the owner's manual says 86 MPH in 3rd gear, which is faster than the 80 MPH you listed for 4th gear... And why does the owner's manual only list the first 3 gears for a 5 speed manual trans...?
#2 | |
Yet, both you and the manual say 31 MPH in 1st gear... There's nothing wrong with revving these engines to redline - even on a relatively frequent basis. This engine is a DOHC/16 valve with variable valve timing. It's designed to rev. I did it with all three of the 4 cylinder Toyotas I've owned for many, many miles and never had a problem. So I'm going by the owner's manual recommendations when I'm looking for strong acceleration...
#3 | |
These 1.5 liter Yaris engines have no problem with revs. They have strong, lightweight internals and a valvetrain that's built for it. I plan on running Mobil 1 exclusively in it after the first change. My '09 LS3 Corvette redlines @ 6,500 RPM and that's a pushrod, 6.2 liter V8. That's only got 1,200 miles on it and it started seeing redline after 600 easy break-in miles. It's a nice DRIVING car. Too bad GM has to ruin it in the usual way (cheap seats, crappy sounding stereo and electronics/power accessories that break constantly).
Drives: Yaris 1.3 AT,Mica Black Join Date: Sep 2010
''There's nothing wrong with revving these engines to redline - even on a relatively frequent basis. This engine is a DOHC/16 valve with variable valve timing. It's designed to rev.''
Hello there, I dont understand this? Are not all engines desinged to rev?wats special abt yaris,every other model also has vvt,n other car manu. gives it other names. eg honda - ivtec. How frequent is relatively frequent ? everyday 10 times is ok?Doesnt this wear out the engine,instead of the car lasting 200000 kms at peak efficenicy it might taper of at 150000,isnt that a concern? |
#5 | |
![]() Drives: 2008 Yaris Sedan 5sp Join Date: Oct 2008
Interesting
