Old 11-04-2008, 07:41 PM   #1
voodoo22
Drives: Yaris Sedan (auto)
Originally Posted by bobby View Post
The Phit is an economy car...the Mini (much more expensive) is essentially a sports car. You're comparing apples & oranges. If you want to compare, you need to look at the Yaris, Versa, Aveo, Accent & Phit. The Mini (which I love, I think it's terribly cute) is in a different class.
When we bought our Yaris an equally equipped Fit was a little less than 3000 more and a Mini was less than 3000 more than a Fit.
voodoo22 is offline
Old 11-04-2008, 07:43 PM   #2
voodoo22
Originally Posted by blktiger60 View Post
The mini doesn't compare to an MR2 and they are way cheaper in all aspects.
MR2's were fun cars, but they don't compare to the new Mini's in many regards except fun. The MR2 was a 2 seater mid engine car.
voodoo22 is offline
Old 11-09-2008, 11:44 AM   #3
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
Originally Posted by voodoo22 View Post
Good points.
and is geared irresponsibly so that it gets worse fuel economy.
LOL. Way to make an over-the-top comment.
Its fuel economy is 1-2 mpgs off a Yaris (Canadian ratings anyways). And that equates to "irresponsible" gearing. C'mon hahahahaha that comment's a joke.
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic
Jem_hadar is offline
Old 11-09-2008, 03:57 PM   #4
voodoo22
You could have worded your response in a much more mature way if you didn't understand where I was coming from.
My statement is only a joke if you think the Yaris' mileage should be the best in class. If Honda geared their cars better they could be rated better than a Yaris and have more potential than it currently has. They also would have qualified for $1000 back from the now defunct eco rebate program. If losing 1000's of sales over the past couple of years simply because of poor gearing choices is a joke, than that's some pretty bad humour.
voodoo22 is offline
Old 11-04-2008, 04:19 PM   #5
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
mpg = yaris is better
price overall = yaris is better
looks wise= yaris rear end is better..i kinna like the new front for the phit.
0-60= as far as i know the yaris can do 8.5 sec which is same as the new phit
now if we gonna talk about interior then the phit win that foh sure..
I think I have figured out the Yaris / Fit MPG Pros and Cons for AUTOMATICS ONLY, since that's what I own.
The Yaris seems to get better city MPGs when NOT hypermiling. Normal driving by normal people. (ie - Folks who would never want or use a ScanGuage, like my wife)
The Fit shines in MPGs on the Highway when NOT hypermiling.
The Fit has 5 gears with what seems to be overdrive as well since my RPMs will drop when cruising eventhough i'm already in 5th gear.
My Yaris, with cruise control wont get much above 40MPG at 65MPH.
The Fit just loves 65MPH and gets close to 50MPG at 60 MPH with cruise control.
If you do mostly highway travel, the Fit may be your buddy, by about 10MPG. If you are city mostly, the Yaris is the car for you.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline
Old 11-04-2008, 08:06 PM   #6
voodoo22
Out of over 60 full tanks on our AT Yaris Sedan I've only had 3 tanks (39.8, 39.2 and 37.6) less than 40 US MPG and all of those tanks were driving 75 mph + on highway trips. I also have some over 40 MPG tanks driving those speeds.
My worst tank by far was driving 75 mph minimum and upwards to 80 mph on an entire tank in the rain and wind.
If I drove a steady 65 mph on my commute I would consistently get over 40 and closer to or over 44 MPG, If I drove 65 mph on a highway trip (so there would be no city driving) I would get closer to 47 MPG. If I drove a steady 60 mph in our Yaris sedan I would also get close to 50 MPG, maybe 47-49 MPG.
In my experience, our Yaris isn't capable of breaking 50 MPG on an entire tank without engaging in slower than 60 mph though(I drive 50 -55 to get those numbers), so if you're getting 50 mpg and going 60 mph, that is better than the Yaris. I haven't seen anyone else report numbers like that yet. This is great news for you and hopefully for all the new Fit owners. I just don't understand why I'm not seeing any other Fit owners on cleanmpg reporting numbers like this.
voodoo22 is offline
Old 11-04-2008, 04:30 PM   #7
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i did not know that.. the new fit with 118hp can do 50mpg on hwy.. wow.. then again i did 45 mpg going 100 km/hr 95% on hwy on the way to camping last summer ..and thats me not using hypermill though..
marcus is offline
Old 11-04-2008, 04:37 PM   #8
nsmitchell
nsmitchell's Avatar
i did not know that.. the new fit with 118hp can do 50mpg on hwy.. wow.. then again i did 45 mpg going 100 km/hr 95% on hwy on the way to camping last summer ..and that sme not using hypermill though..
I got 46.6 MPG going through mountains with my Fit. This MPG was calculated at the pump, not using the Fit's MPG guage.
My jaw dropped to the ground when I calculated this.
I may be doing a Roanoke trip shortly so I can do another pure highway test. I will be going through rural highways with some lights. My Yaris has gotten wicked MPGs while hypermiling this route, like 46 MPG. This will be an interesting test.
Get YarAss in gear!
RIP - Casey Tatum
Old 11-05-2008, 10:54 AM   #9
nsmitchell
nsmitchell's Avatar
voodoo - Were you using crusie or foot control. With Foot Control you can get better MPGs. I am using cruise control in both cars to be fair. Now I do have Michelin HydroEdge tires on my Yaris that are slightly wider than stock, so that may be affecting my MPGs. On my Yaris they are pumped to 44PSI. On my Fit I have not touched the stock tire pressure. Haven't even removed a valve stem cap. With the Fit Sports low profile tires, I don't think I'm going to inflate them over the reccomended PSI just for ride comfort. The Fit is a little rough over rough roads, but in a good way.
Get YarAss in gear!
RIP - Casey Tatum
Old 11-05-2008, 11:27 AM   #10
voodoo22
That makes some more sense. I don't have cruise control. So you're possibly taking a double hit with cruise control and wider tires on your Yaris vs ours which is still on oem Bridgestones.
I know around here, it's just hilly enough that MPG would suffer a lot with cruise on, not so much in the prairies.
Thanks for helping me figure out what you're saying.
I'd still check your psi on your Fit if I was you. Who knows what whomever was smoking when they filled your tires. I just got the Yaris from an oil changed they pumped my tires between 30-36 psi.
voodoo22 is offline
Old 11-05-2008, 02:50 PM   #11
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
are your numbers all highway miles?
the best i've been able to achieve on the highway in my yaris (manual) is 45 mpg (u.s. gallon), that's travelling a top speed of 110 km/h
are you saying that you aren't adjusting your driving to get such good numbers?
stuffy is offline
Old 11-06-2008, 08:45 AM   #12
voodoo22
Most of my tanks are a majority of highway miles, but I have some where I've achieved high 40 US MPG in mostly heavy traffic in downtown Toronto. That does involve thinking about FE to achieve. Turning the car off at long lights, accelerating slowly and coasting to red lights.
However, my highway mileage often includes bumper to bumper traffic jams (you are probably familiar with the 401? I drive Markham Rd to Mississauga Rd, everyday to work). The worst one was last year, it took me 3 hours to get to work instead of the usual 40-50 minutes.
To get over 40 US MPG on highway driving takes no adjustment to my driving at all. I can get between 40-44 mpg (depending on other coniditions) even if I'm going 75 mph the majority of the time. Usually closer to 40 and a few times below that, but barely.
For me to get over 50 US MPG consistently I do have to drive slow, the weather has to be warm and I can't do much more than 50% city driving on a tank. Going over 55 mph very often, will kill a 50 + US MPG tank for me.
In the warm weather, you may be surprised how easy it is to get over 50 US MPG if you aren't driving all city, as long as you try to stay between 50-55mph and don't drive in the mountains like Bailout.
voodoo22 is offline
Old 11-06-2008, 09:50 AM   #13
stuffy
stuffy's Avatar
i'd love to see how you get such good numbers in the city, i drive like a grandma, coast to lights, shut off engine on long lights but the highest i've gotten in the city is high 30's.
my trips are usually fairly short though, so this could be where i'm really taking a hit on the FE.
i can achieve the mid 40's on the highway, but not travelling faster than 110 km/h (that would be around 70 mph i think), anything over 110 my FE drops significantly.
i've had the yaris now for 3 years and have tracked the FE since the car was new, so i pretty much know what to expect depending on driving conditions and the time of year- that's why i found your numbers a bit high.
stuffy is offline
Old 11-05-2008, 11:54 AM   #14
nsmitchell
nsmitchell's Avatar
Good Point. My brother has a nice Craftsman digital tire gauge and I just bought a new tire pump.
Get YarAss in gear!
RIP - Casey Tatum
Old 11-06-2008, 09:59 AM   #15
Fruit Fly
KCALB SIRAY is offline
Old 11-07-2008, 02:47 PM   #16
stuffy
stuffy's Avatar
that's probably what it is, my city trips are probably under 20 km round trips.
i don't have a scanguage either, but you're probably going to get a more precise reading by just crunching the numbers after filling up-
i would like to try out a scangauge to see specifically what kind of driving is giving me the best FE, but to spend a couple hundred bucks on it is not worth it even in the long run.
it would be nice to buy one as a group and give everyone a month with it to help them improve their driving, then pass it on to the next person.
stuffy is offline
Old 11-08-2008, 09:19 AM   #17
voodoo22
That's my exact way of thinking. A scan guage isn't going to give enough of a benefit to pay for itself on our cars unless you were getting horrible numbers now and hopefully the next cars we have will have similar technology built into it.
voodoo22 is offline
Old 11-08-2008, 02:34 AM   #18
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
I'd choose my silver egg over any other car in it's class anyday. It's small, inexpensive, good on gas, reliable, ..and surprisingly a chick magnet (wasn't expecting that, but I'm not complaining)
SilverBack is offline
Yaris vs Fit vs Versa SimplyYaris General Yaris / Vitz Discussion 45 07-15-2010 11:27 PM
Lower Mainland Yaris, Echo, Fit, Mini, meet mojoyaris Canada 24 11-02-2008 02:16 AM
Good Bye Thomas Thread uncleyaris General Yaris / Vitz Discussion 27 07-05-2007 09:38 PM
