If you plan to run 205 rubber, choose ET42 or higher.
If not lowering, then ET40 will work fine; however, 205mm tyre sidewalls will generally protrude up front just a tad with ET40. Of course, it depends on tyre brand and accuracy of wheel offset. If lowering, there is a far greater chance of rubbing with ET40. Hard to believe, but a couple of mm's make the difference.
#4 | |
I didn't ask about tires because I was hoping I'd be able to run the stock ones, at first anyway, unless thats a horrible idea, in that case I'll have to wait a bit longer so I can afford to get wheels and tires.
And Nate, thanks for breaking it down so well. I'll see if I can find a set of Enkei for around 400. I've been checking craiglist often but 15" are hard to find. Mostly I see alot of 17" and up. Last edited by Luna V 2.0; 10-25-2008 at 10:21 AM. |
| steering wheel setup | aucorium | Cosmetic Modifications (Exterior/Interior) | 0 | 07-24-2007 01:05 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
| WANTED: 4 Wheel Covers | galaxyhillvt | Items for Sale by private party | 2 | 07-11-2007 04:05 PM |
| Yaris wheel rate ratio (06+) ? | dsc_pat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 07-05-2007 05:43 PM |
| PIMP Wheel for the yaris | EnduroMTS | Sponsors Classifieds Area | 32 | 11-06-2006 05:23 PM |
