Old 10-25-2008, 02:55 PM   #1
CB900F2
Drives: 08 Sedan
Cruise Control - Again!
I have a 08 CND Yaris Sedan with the convenience package, and I am wanting to install the Factory installed cruse control unit, but not wanting to Rostra version...
I have been doing a lot of research and found the following and I think the Yaris with the convenience package is all prewired for the Factory installed Cruse Control unit, and it is all but a matter of getting the control module and replacement rear cover for the steering wheel.
But there a few things to confirm:
Reference the online 2007 Yaris Factory Service Manual that is a sticky. And look at the CC section. I also reviewed the wiring diagram, and compared it to the car and it looks like all Cruse control wiring is in place, even the wiring going to the ECU, and the steering wheel connector is the 3 wire as required.
1/ The 2007 Factory Manual shows all that is needed is the Cruse Control for ATM…
2/ I reviewed Toyota EPC, again it is for the 2007 Yaris, and it shows for 2007 CND Sedan, there is a reference for the Cruse Control Module that is in the steering wheel. Anyone have access to the 2008 and 2009 EPC? As thecruse control parts on the 07 catalog, there is a reference link and it does not work..
http://www.toyodiy.com/parts/p_U_200...PRKK_4504.html
3/ Based on the 2007 EPC, it looks like the ECU is the same as long as it is the Yaris Sedan with the convenience package or higher.
4/ I went the dealer ship and saw the 2009 Yaris, and again, the Sedan with enhanced convenience and appearance package, it comes with the Factory Cruse control..
Anyone on our forum that works for a Toyota dealership and has access to 2008/2009 Toyota EPC and hopfully has Canadian Spec Yaris also to confirm part#s and ECU??
What do you guys think?.. Am I chasing a ghost?
CB900F2 is offline   Reply With Quote
Old 10-25-2008, 05:14 PM   #2
I don't have access to the EPC, but attached are the EWD's for factory cruise for 08 and 09. The pinouts associated with cruise are identical for both. (Save them locally to view, as they are huge images to be readable)
Old 10-25-2008, 07:43 PM   #3
CB900F2
Drives: 08 Sedan
Scott..
Thanks for the two EWD, but the files are very hard to read if I zoom into them..
Where can I get a copy that is easier to read?
thanks Scott..
Old 10-25-2008, 08:49 PM   #4
Scott..
thanks Scott..
Refresh the thread - I didn't realize that image bucket defaults to resizing to 1024x768. I re-uploaded them at full res, which updates them in the thread as well...
Old 10-25-2008, 08:52 PM   #5
CB900F2
Drives: 08 Sedan
Thanks Scott.. Do you mind me asking where you where able to find them?
thanks again!
Old 10-25-2008, 09:04 PM   #6
thanks again!
I purchased the EWD's for 08 and 09 from Toyota TechInfo.
Old 10-25-2008, 09:44 PM   #7
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
No such thing as a factory cruise. Dealer-installed. This has been covered numerous times.
Old 10-25-2008, 09:54 PM   #8
CB900F2
Drives: 08 Sedan
Take a look at your local Toyota and see if they have 2009 models in stock, and find a S/D with the enhanced convenience and appearance package, and you will find the factory installed CC.... Hope this helps...
Old 10-28-2008, 12:25 PM   #9
b_hickman11
Drives: 08 Sedan
Yes there is.....
Old 10-25-2008, 10:18 PM   #10
firemachine69
Not in Canada. Although that may have changed for '09. (I believe my salesman was pitching that to me, although I can't recall for certainty).
Old 10-28-2008, 07:24 AM   #11
CB900F2
Drives: 08 Sedan
For this project, I am wanting to find out based on now that the 09 CND version does have CC as a factory install, the part# for the steering wheel control unit.
Also, if there is anyone who works for a Toyota dealership and has access to ECP, and not sure if their ECP will include CND spec cars, and from the link I have above of the steering wheel, what does the link to referenced PNC 84632 tell us?...
Also, for the years of 07, 08..The steering wheel CC switch assembly, is it the same one use in Corolla, Camery???
But now, the best thing for us is to find out the parts listing for 09 and cofirm the part# for the CC control unit..
thanks
Old 10-28-2008, 12:28 PM   #12
b_hickman11
Drives: 08 Sedan
My 2005 Tacoma had the same CC assembly as my 2008 Yaris(with power package). My parents 2001 Tacoma has the same CC assembly as my 2007 Yaris(without power package). Therefore I believe that all Toyota's, to at least 2001, have the same CC assembly.
Old 10-28-2008, 04:04 PM   #13
Here are the parts shown in the EPC for 2009:
84632-34011 - Switch, Cruise Control Main
84633-42030 - Wire, Cruise Control
88280-14030 - Switch Assy, Clutch (M/T only)
90159-51099 - Screw, W/Washer - quantity 2
45184-52130-B0 - Cover, Steering Wheel Boss, Lower (Cruise Control-With)
(The big question is if this is truly all that is required. If you look at the EWD, it really looks like everything is built in except the column switch and the clutch switch).
Old 10-28-2008, 06:55 PM   #14
CB900F2
Drives: 08 Sedan
Scott..
YOU DA MAN!.....
Would it be possible if you can look through the EPC for the US ver 08 Sedan with the power package as b hickman11 stated this version of the 08 Sedan came with the factory CC and confirm the the 08 model uses the same part#s
Also.. Does anyone know if the one was to order from the dealer an ECU if it requires to be flashed, or do they come preflashed (Program).. Rockland should be able to help us on this...
Old 10-28-2008, 09:46 PM   #15
Scott..
YOU DA MAN!.....
It is a bit difficult to verify without a VIN number with the specific config, but it looks like:
2009 ECU USA SED&LB Auto - 89661-52J50
2008 ECU USA SED Auto - 89661-52G41 (11/07 - 08/08)
89661-52G51 (11/07 - 08/08)
89661-52J40 (08/08+)
89661-52J50 (08/08+)
There is no indication of cruise in relation to ECU part #.
Old 10-29-2008, 07:09 AM   #16
CB900F2
Drives: 08 Sedan
Thanks Scott..
Guys. Take a read on the same upgrde on a 09 Corolla...
http://www.toyotanation.com/forum/sh...ht=84632-34011
Also.. take a read on the installation guide, and the tool that they use to cut open the back steering wheel cover to allow the cc control to pass through.. Anyone seen this, or knows of the manufacture,part# etc... I would like to find out more details on it..
http://www.trdsparks.com/install/00016-01208inst.pdf
P.S... Looks like we can order this kit as it is the same CC unit and wire set used in the Corolla 09 and the Yaris...
Old 10-29-2008, 08:00 AM   #17
Thanks Scott..
I just looked up the 09 Corolla and it has a different part number for the switch and the wire for NAP, but same parts as Yaris for JPP:
For NAP Corollas:
Switch, Cruise Control Main: Corolla 84632-08021 vs Yaris 84632-34011
Wire, Cruise Control: Corolla 84633-0E020 vs Yaris 84633-42030
As for the tool, it is just a die punch - Two drill bits would accomplish the same task.
Old 10-29-2008, 06:52 PM   #18
CB900F2
Drives: 08 Sedan
Alright guys, whos in!...
Any 07,08 willing to take the plunge??
Yaris.. Cruise Control. peanut New YARIS Purchase Forum 28 11-26-2017 06:17 AM
Cruise Control in the LB RobotMan In Car Entertainment + Electronics (audio / video / alarm) 1 09-30-2007 02:43 PM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
