Old 10-26-2008, 07:04 PM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Originally Posted by largeorangefont View Post
My wheels are +40 and had a slight fender rub due to the 205 50 16 tires.
With the Tokico struts in installed, I rarely rub anymore.
I just cut my bumpstop to the plastic piece for insurance. I have only hit the bumpstop a couple times ever, and I'm lowered 1.8 inches.
Must be the stiffer struts... Did you have the lowering springs installed on the stock struts, and if so did you hit the bump stops considerably more with them?
I ask because based on my measurements, you don't have much travel left. I'm guessing 1/2 to 1 inch...
PetersRedYaris is offline   Reply With Quote
Old 10-26-2008, 11:42 PM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Yea, I ran for 20K miles with the same lowering springs on the stock struts.
The only time I ever hit the bumpstops, was over potholes at speed. I drive the car pretty fast into turns. and with the new struts I get less tire rub on the fender liner, but never ride the bumpstops through turns.
I have more than 1 inch of up travel.
Lowered Cars Please Read - Bump Stops!!! Galavoxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 11-11-2010 04:49 PM
Bump Stop kits now available.... Galavoxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 04-25-2007 12:51 AM
