Old 10-27-2008, 01:21 PM   #1
By the muffler, bent shape like a "s" or "l" with a rubber stopper/grommet on the end between both of them. can't miss it if you look under the rear.
Old 10-27-2008, 02:04 PM   #2
gid
+1 on rubber grommet ...
this could have came loose or tore . This stretches so exhaust can move some with the road conditions ( bumps , etc. ) . It slips on two metal rods , 1 attached ( welded ) to undercarriage and the other welded to muffler itself . This was an issue with our 2000 Chevy PRIZM ( Corolla ) . Overtime the rubber grommmet weakens from the elements and stretches from the torture of pour roads . The grommet had weakened so much that the muffler would move up and down from rough surfaces or bumps , thus the tailpipe would hit on the rear plastic bumper . To test this , grab tailpipe and move up and down to see the play in it , if hits the bumper , that could be the culprit . This is a very expensive item , think I was quoted at about $150 ! So , we decided to just deal with it . GOOD LUCK
Woof's Big Rear Sway Saga..... woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-02-2007 11:24 PM
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 03:06 PM
