Old 10-27-2008, 05:27 PM   #1
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Don't cut ..........period
Old 10-27-2008, 05:50 PM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
You like the feeling of compressed foam between your a-arm and strut tower? Why not just take your springs out and sit on the bumpstops? It wouldn't ride any different...
Or are you saying get the fatcats?
I also see you have the TRD Sportivo struts/shocks, this doe's not apply to them...
PetersRedYaris is offline   Reply With Quote
Old 10-27-2008, 06:28 PM   #3
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Yes I have the TRD shocks with the Tein springs . They work VERY well , even on dirt . From my past experiences with other shock/spring combos ,I found that if you are not lowering more than 2" cutting the bumps will shorten the lifespan of your shocks . If you cut the bumps the energy transfered will be greater . Keep in mind the idea behind bumps is to dampen .
If I were to switch bumps it would probably be with energy suspension bumps .
Lowered Cars Please Read - Bump Stops!!! Galavoxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 11-11-2010 04:49 PM
Bump Stop kits now available.... Galavoxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 04-25-2007 12:51 AM
