Old 10-29-2008, 04:05 PM   #1
Astroman
Modded Moderator
Astroman's Avatar
Wonder when the naysayers will start posting that it does nothing?
If I ever have mod money again, I might try this. Is there still a way you could keep those rear belts?
Old 10-29-2008, 04:22 PM   #2
I don't see how you could keep them in this situation, you'd have to shorten the bar. It looks adjustable but to what lentgh i'm wondering (the nut on the end of the bar at each end). I'll have to look at my belt when I get out of here. Depending on the width of the belt mount area it could just slip over it, but I highly doubt it.
Old 10-29-2008, 04:26 PM   #3
Even if you could keep the belts, the bar is positioned forward of the rear seat backs. People be whacking their heads on it.
Old 10-29-2008, 04:29 PM   #4
Looks pretty high though, you'd have to have someone about 6' 5" to hit IMO. I'd swipe the pads off my sons huffy and wrap em around it, lol
Old 10-29-2008, 04:33 PM   #5
Astroman
Modded Moderator
Astroman's Avatar
Nerf bar style
Old 10-29-2008, 08:59 PM   #6
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
That upper bar works a bit, in hatchbacks, but you can't have anyone in the back seat so that kinda sucks.
The lower bar on top of the shocks is worth the money you can get for it at the recycling center. It does even less than the front strut bar, and just adds weight and cuts down on cargo space.
To Rockland,
You are implying that the bar made the car is "stiffer" and "ride better" all at the same time? Not that I think you are in any position to quantify handling gains.. but thanks for your opinion. I think if I gave you a battery tie down brace you would say the car handled better.
Old 10-29-2008, 10:03 PM   #7
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
So just get this an a sway bar and you'll be set? (Thinking about getting one myself along with a sway bar. :P)
Old 10-29-2008, 11:00 PM   #8
largeorangefont
Break'em off some.
I would get a rear sway bar, and the front lower subframe brace. Braces in that area are actually effective. If you don't have a sway bar, definately get one before spending ANY money on braces.
Old 10-29-2008, 10:49 PM   #9
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
To Rockland,
this man i guess has no clue to my suspension setup oh well another brillant answer from the other side.......
Old 10-29-2008, 11:02 PM   #10
largeorangefont
Break'em off some.
Then enlighten us all as to how the bar made your car stiffer (which you have no way of quantifing) and ride better all at the same time.
I don't need to know your suspension setup to ask you a question about you own comments in post #1.
Old 10-30-2008, 10:06 AM   #11
He simply made an observation, that's all. Even if his words were not the correct ones to describe the feeling, which I'm not saying they are wrong, he still noticed a difference in the way the car reacts. Do you need Loren to back you up on this to justify and say I'm wrong?
Old 10-30-2008, 11:45 AM   #12
largeorangefont
Break'em off some.
The reason the car felt better was because his wallet was lighter.
Old 10-29-2008, 10:57 PM   #13
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
To Rockland,
You mean those billet battery tie down braces don't improve handling
Old 10-29-2008, 11:03 PM   #14
largeorangefont
Break'em off some.
They do. Ask Rockland
Old 11-01-2008, 11:00 PM   #15
ddongbap
To Rockland,
That last part was fking hilarious.
Actually this entire post was a good read. Rockland was actually right about something. Sucks it had to be at his expense tho.
Old 11-02-2008, 12:28 AM   #16
largeorangefont
Break'em off some.
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
My Newest Exterior Mod fallensoldier1986 Cosmetic Modifications (Exterior/Interior) 22 05-08-2007 11:15 AM
newest mod!! turboyaris Performance Modifications 21 04-14-2007 04:51 PM
Torque Settings, front suspension Nimble Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-21-2007 01:00 PM
