![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Most important guages for boosted engines?
Once I install the Blitz, what three guages are most important for monitoring the health of the engine?
I already have a ScanGuage so I can monitor water temp.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
not critical with supercharging, but I would say a boost gauge and oil pressure, since you already have water temp.
boost, oil, pyrometer so if you hold it long you dont fry your pistons
i run all three for my turbod tc and water temp, and wideband, my old supercharged delsol i ran those three and a wideband
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
oh yeah, add a wideband A/F that one is fun to watch too
Ok, but other than fun to watch, will the A/F wideband warn me that something is about to blow up? I can see the point of oil pressure and water temp. Never knew the purpose of wideband.
the pyrometer will tell you if your pistons about to melt. a/f wideband would tell you if its to lean or to rich or right on the money
Bathroom + Laptop = <3
i would say boost/oil pressure/AFR.... any car that you plan on tuning correctly NEEDS a wideband... people think they can use the narrowband signal to tune... thats a bunch of hoohah, but the wideband will cost you a pretty penny over the others
I used to have 1700 posts
who makes a good wideband AFR gauge
Break'em off some.
If you have a turbo you will want:
Boost, EGT, oil pressure, water temp If you are supercharged you will want: Water temp, oil pressure, EGT, boost if you have extra $. Wideband is fine for both, but EGT is going to be more important, especially in a turbo car. If you have a scangauge, I would not waste the cash on a wideband. The scangauge should be able to monitor fuel pressure, which will give you a window into the fueling system. Between fuel pressure and EGT you will be able to tell if you have a fueling problem. EGT is more critical to the health of the engine, especially with a turbo. If you are doing your own tuning however, then you will definately want a wideband. |
Break'em off some.
Break'em off some.
Break'em off some.
i use innovate LM-1, but it is handheld and i have an extra one lying around somewhere... but on cars that people dont feel like getting a bung welded in, i use the exhaust clamp which gave me a steady 14.5 AFR reading at idle out of the Envoy i drive... and that was at the end of the tailpipe but the HPtuners scanner software read 13.06 :-/ whacky interfaces
what should the AFR be on a blitz supercharged yaris?
Break'em off some.
i saw a pic of camelll's gauge reading 13.1 at 9 pounds of boost whats ur take on that?
i use plx
Break'em off some.
| NST (NonStopTuning) Pulleys. Info, Specs, User Data... | NonStopTuning | Performance Modifications | 636 | 12-13-2013 09:47 PM |
| Gauges! Gauges! Gauges! at Blow Out Price. | MC-BPT | Sponsors Classifieds Area | 5 | 06-07-2007 09:55 PM |
