Old 10-30-2008, 06:26 AM   #1
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
all keyless entry systems you buy are for powered door lock no keyless entry comes with the actuators as they are designed for cars with powered door locks. what you would need to get is the keyless entry and 2 door lock actuators to add the powered lock portion. and wont add any switchs youll get two key fobs in my opinion
door lock actuators need two of them
viper 211hv
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-30-2008, 08:32 AM   #2
viper 211hv
Make sure you get three - You really want the hatch to unlock as well. If you can find a set of actuators from a junk yard car life would be easier. The aftermarket ones work fine, but sometimes figuring out a good way to mount them can be tricky.
Old 10-30-2008, 09:52 AM   #3
Midon
Mod Freak
Drives: 88 MR2 GT
was there a power lock for the LB in 08
Midon is offline   Reply With Quote
Old 10-30-2008, 10:09 AM   #4
Yes.
The Part Numbers for the OEM Toyota parts are:
Lock Assembly, Front Door W/Motor, RH: 69030-52470
Lock Assembly, Front Door W/Motor, LH: 69040-47060
These replace the standard lock assembly
Actuator Assembly, Back Door Lock: 69150-52070
Mounting Bolts: 91511-B0614 (2 required)
This is an addition to the rear lock assembly
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
dealer trade-in payoff question.. kapo New YARIS Purchase Forum 1 07-16-2007 10:27 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
question bout aux port SurfBabe900 General Yaris / Vitz Discussion 1 05-28-2007 02:18 PM
Question on Yaris wheels featherz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-17-2006 10:27 PM
