Old 10-30-2008, 07:02 AM   #1
CB900F2
Drives: 08 Sedan
Anyone, Anyone, Anyone???......
Hmmm... What would be holding some of you CC wanters back??
Old 10-30-2008, 12:24 PM   #2
b_hickman11
Drives: 08 Sedan
This has already been done. There were many threads about this topic pre-hack.
b_hickman11 is offline   Reply With Quote
Old 10-30-2008, 08:22 PM   #3
CB900F2
Drives: 08 Sedan
B... I dont recall any of the threads mentioning any of our members trying to connect the OEM CC switch assemble with the required wiring harness to the steering wheel connector to test it… Unless I over look it…
Can you elaborate on the issue that was found back then?..
- Was it a wiring issue?
- ECU Issues?
Thanks…
QUOTE=b_hickman11;160196]This has already been done. There were many threads about this topic pre-hack.[/QUOTE]
Old 10-30-2008, 11:42 PM   #4
b_hickman11
Drives: 08 Sedan
are you wanting the CC that comes with the power package or the one that comes without the power package?
Old 11-01-2008, 05:57 AM   #5
CB900F2
Drives: 08 Sedan
I assume in the US, the PowerPackage is the package that came with the factory OEM CC switch that is built into the steering wheel as noted by Scotts parts diagram.. If so, yes...
b, you noted that you have a sedan with the power package and cc, do you mind checking your ECU part number?, it will be noted on the front of the ECU on a sticker..
thanks
Old 11-01-2008, 12:50 PM   #6
b_hickman11
Drives: 08 Sedan
thanks
Yes I have an 08 with the power package that has CC and an 07 without power package that has CC. The power package CC is always mounted on the right side of the steering column while the non-power package CC is mounted on the left side of the steering column.
I will check my ECU part number....One questions though, where is the ECU? I know Im a noob....
Old 11-01-2008, 01:16 PM   #7
CB900F2
Drives: 08 Sedan
In the engine bay on the left handside on the back wall.. You will see two large connector on the top of it.. the label is in the middle of the ECU on the face..
If you can, can you check your 07 and 08?
thanks
Old 11-02-2008, 11:37 PM   #8
b_hickman11
Drives: 08 Sedan
thanks
89661-52G51 Power Package
89661-52F11 Non Power Package
Old 11-03-2008, 07:14 PM   #9
CB900F2
Drives: 08 Sedan
Thanks for the feedback...
My 08 Sedan has the same ECU as your 08 with the PP and OEM CC..
So, it looks like all of the planets are pretty much all lined up…
Confirmed ECU, Wiring is in place, Confirmed part#s…. Just need to try it now..
Old 11-01-2008, 07:17 AM   #10
Midon
Mod Freak
Drives: 88 MR2 GT
I want to do this, but what parts would I need 08 LB MT and all I got was a premium audio system, so I don't know which ones I need.
Midon is offline   Reply With Quote
Old 11-01-2008, 07:23 AM   #11
CB900F2
Drives: 08 Sedan
All of the items below...
84632-34011 - Switch, Cruise Control Main
84633-42030 - Wire, Cruise Control
88280-14030 - Switch Assy, Clutch (M/T only)
90159-51099 - Screw, W/Washer - quantity 2
45184-52130-B0 - Cover, Steering Wheel Boss, Lower (Cruise Control-With)
Old 11-01-2008, 07:27 AM   #12
Midon
Mod Freak
Drives: 88 MR2 GT
Got it I will have to get this done after my current MOD. Printing the list right now.
Yaris.. Cruise Control. peanut New YARIS Purchase Forum 28 11-26-2017 06:17 AM
Cruise Control in the LB RobotMan In Car Entertainment + Electronics (audio / video / alarm) 1 09-30-2007 02:43 PM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
