Old 10-30-2008, 11:35 AM   #1
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
who makes a good wideband AFR gauge
Old 10-30-2008, 12:08 PM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
AEM, Dynojet, Autometer, Innovate, Dynotune. You can get one from $250-$350 it just depends on what features you want.
Old 10-30-2008, 08:42 PM   #3
nemesisz
559 Before the Hack
nemesisz's Avatar
Drives: 07 Yaris LB
PLX Devices
They make a lot of different products. They are popular in the 300ZX and 350Z arenas. If I were to get a wideband Id get on of theirs, AEM or Innovative.
nemesisz is offline   Reply With Quote
Old 10-30-2008, 12:06 PM   #4
largeorangefont
Break'em off some.
If you have a turbo you will want:
Boost, EGT, oil pressure, water temp
If you are supercharged you will want:
Water temp, oil pressure, EGT, boost if you have extra $.
Wideband is fine for both, but EGT is going to be more important, especially in a turbo car.
If you have a scangauge, I would not waste the cash on a wideband. The scangauge should be able to monitor fuel pressure, which will give you a window into the fueling system. Between fuel pressure and EGT you will be able to tell if you have a fueling problem. EGT is more critical to the health of the engine, especially with a turbo.
If you are doing your own tuning however, then you will definately want a wideband.
Old 10-30-2008, 12:10 PM   #5
largeorangefont
Break'em off some.
Originally Posted by kurokoma-kun View Post
where are the rest of you locating the wideband a/f O2 sensor? header or midpipe? i really hate to drill a new hole on my header if i can locate it on the pipe
It needs to be before any cats, and clocked above 9 and 3 on the pipe to avoid sensor damage.
Old 10-30-2008, 12:25 PM   #6
largeorangefont
Break'em off some.
on that nitto midpipe there's a few inches of pipe right behind the collector b4 the first resonator, that'll be a good spot... now if only i could weld
a muffler shop will be able to handle it.
Old 10-30-2008, 01:30 PM   #7
whooppee777
what should the AFR be on a blitz supercharged yaris?
Old 10-30-2008, 04:37 PM   #8
largeorangefont
Break'em off some.
I would not got higher than 12:1. Mid 11s would be a very safe compromise.
I run my Cobra at 11.3 to one to keep EGTs down on the track.
Old 10-30-2008, 05:28 PM   #9
whooppee777
i saw a pic of camelll's gauge reading 13.1 at 9 pounds of boost whats ur take on that?
Old 10-30-2008, 07:19 PM   #10
largeorangefont
Break'em off some.
He said it dips to low/mid 11s after that though, which is fine. A second or 2 of 13:1 under boost after throttle tip in is not going to hurt anything.
Old 10-30-2008, 07:25 PM   #11
whooppee777
well now that thats been all cleared up. does the blitz supercharger have an electronic clutch? i was reviewing the installation manual and the wiring diagram and it had this thing for an electronic clutch and i'm assuming thats apart of the S/C bcuz our car sure as hell doesnt have an electronic clutch
NST (NonStopTuning) Pulleys. Info, Specs, User Data... NonStopTuning Performance Modifications 636 12-13-2013 09:47 PM
Gauges! Gauges! Gauges! at Blow Out Price. MC-BPT Sponsors Classifieds Area 5 06-07-2007 09:55 PM
