are you wanting the CC that comes with the power package or the one that comes without the power package?
I assume in the US, the PowerPackage is the package that came with the factory OEM CC switch that is built into the steering wheel as noted by Scotts parts diagram.. If so, yes...
b, you noted that you have a sedan with the power package and cc, do you mind checking your ECU part number?, it will be noted on the front of the ECU on a sticker.. thanks |
#3 | |
I will check my ECU part number....One questions though, where is the ECU? I know Im a noob.... |
#4 | |
In the engine bay on the left handside on the back wall.. You will see two large connector on the top of it.. the label is in the middle of the ECU on the face..
If you can, can you check your 07 and 08? thanks Quote:
![]() ![]() Drives: 2007 5 Door Hatch Join Date: Jun 2007
does the 07 yaris rs have a light on the dash for the cruise? I have the aftermarket dealer installed cruise on the left hand side with a green light on the stick. If I can change to the better looking one I will as I would assume all the parts are there, so a stick change should work. Shed some light into this issue, will it work?
#6 | |
It does seem that way, but for all of the info on the OEM CC unit and the info all being OEM like the Service Manual, EPC, and confirmed wiring is there... and the confirmed 08 model with the enhanced power package comes with the OEM CC, it makes no sense to why the aftermarket unit was pushed as the dealer install option..
I have been searching the local wreckers to find a compatible CC switch which from all of the online Toyota OEM parts suppliers claims that 07+ Camry and many other models of cars use the same CC switch unit... I will then purchase the wire harness once I have the switch and give it a shot (cross my fingers!).. Unless someone can beat me too it! |
#8 | |
89661-52G51 Power Package 89661-52F11 Non Power Package |
Thanks for the feedback...
My 08 Sedan has the same ECU as your 08 with the PP and OEM CC.. So, it looks like all of the planets are pretty much all lined up… Confirmed ECU, Wiring is in place, Confirmed part#s…. Just need to try it now.. |
| Yaris.. Cruise Control. | peanut | New YARIS Purchase Forum | 28 | 11-26-2017 06:17 AM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
| Cruise Control in the LB | RobotMan | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 09-30-2007 02:43 PM |
| Rostra Cruise Control install done on MT | AlexK | DIY / Maintenance / Service | 34 | 09-18-2007 03:21 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
