Old 10-31-2008, 01:29 AM   #19
kou
Drives: 08 lb
this is the custom one i made out of an old audi one i found at work.
Old 10-31-2008, 09:13 AM   #20
joelitton
joelitton's Avatar
Drives: 2008 Yaris Liftback
Send a message via AIM to joelitton Send a message via Yahoo to joelitton
Originally Posted by Smokey159 View Post
Does anyone know if this actually reduced drag and increased MPG?
I have not noticed any change in MPG. But my main functional reason for putting the panel on there was protection from the junk on the road. It seems that around Tampa (on the highways at least) there is a fair amount of debris - strips of rubber from truck tires and other junk ...not ALL over the road of course, but enough that I was concerned. I'd had several times where I'd swerved to avoid stuff - or straddled it and HOPED that I was high enough off the ground that it wouldn't do any damage. I feel a lot better with that panel under there.
2008 Blazing Blue LB. 5-spd MT, Power Package, side airbags, antilock brakes, rear spoiler, bumper guard, splashguards, power locks/ alarm. Added: Tanabe front strut tower bar, Beatrush aluminum underpanel, NST short shift kit, NST crank pulley, WeatherTech side window deflectors, Wheelskins steering wheel cover and shift boot, dual loud FIAMM horns, 30% tint all around, wheel locks. Yet to install: NST alt and WP pulleys. More to come :)
joelitton is offline   Reply With Quote
Old 10-31-2008, 09:14 AM   #21
joelitton
joelitton's Avatar
No , but it looks like a real bitch to do oil changes lol
Changing oil is easy. Less than 5 minutes of total added time to take the panel off and put it back on.
Old 10-31-2008, 09:15 AM   #22
joelitton
joelitton's Avatar
THAT is very cool! ...also cool that you have access to a lift. Many years ago I worked at a gas /service station, and having that hydraulic lift was SUCH a nice side benefit!
Old 10-31-2008, 09:53 PM   #23
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
Not if you do the relocation kit. I plan on trimming a hole in the panel and attaching it back with some bolts to make it easy to remove for oil changes.
Old 10-31-2008, 09:56 PM   #24
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i have this panel on my xA.. odd directions.. a little "translation" and i figured it out.. with a couple extra bolts to spare??? but it stiffened up my bumper at least (good for cone killing)
the under tray bangs into my oversized oil return line :(
Old 11-01-2008, 11:48 AM   #25
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
looked like the beatrush panel wouldn't work with the GT SPEC front lower bar. can anyone confirm this????
Old 11-01-2008, 11:54 AM   #26
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
It will work with the 2 point bar pictured in post # 20. The underpanel only appears to extend to behind the front of the front arms. The GT spec 2 point crossmember brace bolts behind that area.
I don't think it will work with the 4 point ladder brace without cutting the underpanel. It looks to be minor cutting on the rear of the underpanel, and minor fab work to secure it.
Here is the beatrush 4 pt.
Old 11-02-2008, 09:47 AM   #27
Astroman
Modded Moderator
Astroman's Avatar
I need one of these now, I've torn up my plastic stocker pretty bad.
aluminum rims changing ride guality? rg570lvr Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 10-23-2008 01:21 PM
JDM BeatRush SUsp C2AUTOSPL Sponsors Classifieds Area 15 09-10-2007 05:33 PM
aluminum underpanel c-one yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 06-18-2007 04:29 AM
aluminum underpanel turboyaris Performance Modifications 20 05-02-2007 01:39 AM
