Old 10-31-2008, 01:59 PM   #1
33lam
Drives: The C-One Yaris
Send a message via MSN to 33lam
OIL CATCH TANK increase performance?
will the oil catch tank increase the car performance??
33lam is offline   Reply With Quote
Old 10-31-2008, 02:03 PM   #2
ddongbap
No.
Old 10-31-2008, 04:17 PM   #3
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
Originally Posted by ddongbap View Post
No.
+1 there designed to catch oil before it gets to the intake pipe
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-31-2008, 05:43 PM   #4
harveyjai
Touge Driver
harveyjai's Avatar
Drives: Yaris YRX
so what does it do?
Any benefits or harm if installed?
harveyjai is offline   Reply With Quote
Old 10-31-2008, 06:07 PM   #5
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Prevents oil to enter the intake manifold.
This condition over a long period of time has ben known to cause sludge formations and leading to other problems on some other Toyota models.
I have never heard of this problem on the Yaris tough.
To your question: It won't harm you to install one.
Is it really need it? Probably not.
Does it look cool on your engine bay? Yes
Old 10-31-2008, 06:10 PM   #6
battleversiontc
its used on boosted cars. on na cars it wouldnt make any sense to install one not unless you add one and add a filter to the inlet side thats the side that comes from the manifold to valve cover i ran one on my tc then i boosted it so now it beneficial to me
Old 10-31-2008, 06:11 PM   #7
hmm, I don't have one on any of my three boosted cars...
Old 10-31-2008, 06:17 PM   #8
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Not really needed on a yaris.
Old 10-31-2008, 06:16 PM   #9
battleversiontc
try running a clear hose and watch how fast it will build up with oil
ive ran without it before its just an extra security to keepin the valves clean
Old 10-31-2008, 06:52 PM   #10
ddongbap
Does it matter though? Isn't it oiled up under the valve cover anyways?
Old 10-31-2008, 07:31 PM   #11
battleversiontc
nope cause oil is only sprayed out as the pressure increases in the valve cover if the pressure doesnt then nothing. which in boosted cars it does. nas only if you disconnect the hose from the manifold to the valve cover and out a filter on the inlet side there is now an unequal amount of pressure difference created instead of the natural push and pull effect
Old 10-31-2008, 07:33 PM   #12
ddongbap
Made almost complete no sense.
Old 10-31-2008, 07:38 PM   #13
battleversiontc
With a proper catch can setup, the crank case vent is still connected to the air filter box, then you replace the PCV valve on the head with a simple nipple connected to your catch van via a hose. The PCV valve should be moved to the outlet of the catch can to prevent pressurizing the catch can when under boost. From the catch can a hose goes to the intake manifold like normal.
Since most PCV valves leak on turbo cars we end up with a slight positive pressure in the crank case under boost and this back flows out the vent connection into the air inlet hose leading to the turbo crapping it up with oil, water vapor, and blowby gases. .
this is what a catch can does
Old 10-31-2008, 08:18 PM   #14
ddongbap
Whoa, much better. Damn, much better. lol.
Old 10-31-2008, 08:21 PM   #15
battleversiontc
lol thanks i had to type it on the side before my uncle gets pissed cause im not doing any productive work when i should really be doing some parts orders for his body shop
Old 10-31-2008, 11:42 PM   #16
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
cars have ran 100k+++ miles without them, why rice a system that is stable? just do oil changes on time with proper synthetic...
Old 11-02-2008, 01:30 AM   #17
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
The puke can can be useful on an engine with mods, but our cars stock run lean.
I did notice gunk coming out and if you run the car hot enough to burn off the gunk at intake. You should be ok. The stock Yaris driven under normal conditions are ok without it. I only havevto clean out my can every 6 months.
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 11-02-2008, 04:33 AM   #18
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
If you had a stock AFR chart you'll see that the car runs roughly stoichometric till about 4000+ rpms when it goes very rich.
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
$30 Oil Catch Can, DIY Ogredude DIY / Maintenance / Service 79 05-13-2011 11:05 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
