stickie this radio wire colors & alarm wire color reference guide
this should be a sticky
2007-2008 might be same for 2009 not to sure12volts yellow (25A), gray (15A) + ignition harness Starter black (x2)(common) + ignition harness Second Starter N/A Ignition pink + ignition harness Second Ignition green + ignition harness Third Ignition N/A Accessory white + ignition harness Second Accessory N/A Keysense yellow - ignition harness Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors. Power Lock brown - driver kick, 20 pin plug, pin 7 Notes: Meter this wire while turning the key in the driver door key cylinder. Power Unlock yellow to green (double pulse) - driver kick, 20 pin plug, pin 8 Notes: Meter this wire while turning the key in the driver door key cylinder. Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is green (-) at the fuse box, middle, 18 pin plug, pin 15. Lock Motor white to orange 5wi driver kick, 20 pin plug, pin 10 Unlock Motor lt. blue to pink 5wi driver kick, 20 pin plug, pin 20 Parking Lights+ green + fuse box, top L, 30 pin plug, pin 29 Parking Lights- white - headlight switch Notes: Not available on all models. Hazards black - hazard light switch Turn Signal(L) lt. green + fuse box, top L, 30 pin plug, pin 27 Turn Signal(R) yellow + fuse box, top L, 30 pin plug, pin 28 Reverse Light red + fuse box, top L, 30 pin plug, pin 30 Door Trigger see notes - fuse box, top left, 30 pin plug Notes: The LF door is red in pin 21. The RF door is blue in pin 24. The LR door is green or yellow in pin 5. The RR door is blue in pin 20. The rear doors are common on some models. Use all four wires and diode isolate each. Dome Supervision pink - fuse box, L side, 6 pin plug, pin 2 Trunk/Hatch Pin lt. blue - fuse box, top L, 30 pin plug, pin 7 Hood Pin white - pin sw or theft warning ECU, pin 4 Notes: The theft warning ECU is behind the glovebox. Trunk/Hatch Release N/A Power Sliding Door N/A Factory Alarm Arm arms with lock Factory Alarm Disarm disarms with unlock Disarm No Unlock use key sense wire Tachometer lt. green ac data link conn. under dash, pin 9 Wait to start N/A Brake Wire green to purple + fuse box, top L, 30 pin plug, pin 12 Parking Brake yellow - fuse box, top R, 16 pin plug, pin 2 Horn Trigger black to lt. green - fuse box, top, 36 pin plug, pin 28 Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Interface Module: Category: Immobilizer Bypass Required: Yes Type: Transponder Part #: 556UW Alternate Part1 #: DesignTech 20402 Alternate Part2 #: DesignTech 29402 Notes: Optional on the sedans and S sedans, not standard equipment. Headlight lt. blue - headlight switch Trunk/Hatch Release N/A Power Sliding Door N/A Speed Sense purple fuse box, top, 36 pin plug, pin 26 Wipers blue (L), yellow (H) + windshield wiper switch LF Window up/dn red - green A driver window switch in door RF Window up/dn white - pink A driver kick, 18 pin plg, pins 11, 10 LR Window up/dn yellow - black A driver kick, 18 pin plug, pins 8, 9 RR Window up/dn red - green A driver kick, 18 pin plg, pins 17, 18 Radio 12v blue + radio harness Radio Ground white/black - radio harness Radio Ignition gray + radio harness Radio Illumination green + radio harness Factory Amp Turn-on N/A Power Antenna black + radio harness LF Speaker +/- pink - purple +,- radio harness RF Speaker +/- gray - yellow +,- radio harness LR Speaker +/- black - yellow +,- radio harness RR Speaker +/- red - white +,- radio harness
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified Last edited by battleversiontc; 05-07-2009 at 04:29 AM. |
![]() ![]() Drives: 2008 blazing blue yaris LB Join Date: Oct 2008
great info. this should be stickied
http://cardomain.com/ride/3151056 ![]() ![]() mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch coming soon: window tint, custom sub grills, tach and........ |
yup hopefully they do
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
bump
thanks, great info
sweet they stickied it
thanks for making it sticky
![]() ![]() Drives: Yaris 5 door Liftback Join Date: Oct 2008
Just letting people know that when I opened my two front doors on the 2009 4dr liftback, the left door speaker wire was described correctly but the right door had a blue wire, not a yellow. The other wire was indeed gray, however.
Ok I just opened up my LR door and the wires are red and white, not black and yellow. This is for the speaker wires.
well if you find anything else different in the 09 please post as the wires i have are from 07-08 wasnt to sure on the 09 at the time i posted it
Drives: 2008 Yaris Hatchback Join Date: Oct 2009
08 Yaris Front right speaker wires
My 08 Yaris Liftback has gray and blue speakers in the right front, not gray and yellow as all the diagrams I have seen had. I'm hoping the gray was still positive.
Drives: 2008 HB yaris Join Date: May 2012
same as mine,
I just upgraded mine, you are right, my 08 HB has the same color as grey + blue -
![]() Drives: 2007 Yaris Hatchback Join Date: Apr 2010
"Speed Sense purple fuse box, top, 36 pin plug, pin 26" Where exactly is it located?
Im a noob and need to find the speed signal for my navigation unit. |
#14 | |
It's pin 26 on Connector 4B in this image:
![]() Drives: yaris Join Date: May 2010
need help need to get help with my 2008 yaris fatory alarm i need to find the wires plz if you can hellp me as soon as posible plz do i need it fast and if you can hellp me post the piture's where the wire's are okey cool :D:D
Bayou Blue Pearl.
Drives: Yaris 5D Liftback Full Options Join Date: Feb 2010
OH THANK YOU SOOOO MUCH for this! Thanks!
BOSCH 8000k HID Headlights, BOSCH 8000k HID Fog Lights. BOSCH Horn. 30% tint all round. 70% Tint mirror-finish tint on front wind shield. TRD Leather Shift Knob, Leather Steering Wheel, TRD Emblem. Height adjustable driver's seat is cool! and... That great armrest from ebay
always toyin'
I just upgraded my RR and LR stock speakers with a pair of Pioneer 6.5" (TS-A1673R) on my 2010 5-dr hatchback.
The factory wiring colors were: L Rear Speaker: red (+), white (-) R Rear Speaker: red (+), white (-) -toy .
- Procrastinators of the world unite! ...tomorrow. ![]() My Garage.. 'Mild' Drop & Misc..2-DIN GPS/Navi..DIY:Rear Wiper Delay..Ramps/Roll-Ups..Rain Sensing Wipers / Auto-Headlamps |
TRD TURBO
Drives: TRD VITZ TURBO 2003 Join Date: Aug 2010
any1 can help me to find speed sensor wire for a vitz trd turbo 2003?
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
| Factory wire harness or plastic aftermarket piece for aftermarket radio????? | Yarisguy13 | Great Lakes | 1 | 09-17-2007 10:14 AM |
| Keyless Entry Wire Colors? | Kaeon | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 09-16-2007 02:39 PM |
| Radio Wire Diagram????? | Yarisguy13 | General Yaris / Vitz Discussion | 1 | 04-18-2007 10:58 PM |
