Old 10-31-2008, 07:31 PM   #1
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
nope cause oil is only sprayed out as the pressure increases in the valve cover if the pressure doesnt then nothing. which in boosted cars it does. nas only if you disconnect the hose from the manifold to the valve cover and out a filter on the inlet side there is now an unequal amount of pressure difference created instead of the natural push and pull effect
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-31-2008, 07:33 PM   #2
ddongbap
Made almost complete no sense.
Old 10-31-2008, 07:38 PM   #3
battleversiontc
With a proper catch can setup, the crank case vent is still connected to the air filter box, then you replace the PCV valve on the head with a simple nipple connected to your catch van via a hose. The PCV valve should be moved to the outlet of the catch can to prevent pressurizing the catch can when under boost. From the catch can a hose goes to the intake manifold like normal.
Since most PCV valves leak on turbo cars we end up with a slight positive pressure in the crank case under boost and this back flows out the vent connection into the air inlet hose leading to the turbo crapping it up with oil, water vapor, and blowby gases. .
this is what a catch can does
Old 10-31-2008, 08:18 PM   #4
ddongbap
Whoa, much better. Damn, much better. lol.
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
$30 Oil Catch Can, DIY Ogredude DIY / Maintenance / Service 79 05-13-2011 11:05 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
