Old 11-01-2008, 07:06 PM   #1
Originally Posted by Stoln View Post
does the 07 yaris rs have a light on the dash for the cruise? I have the aftermarket dealer installed cruise on the left hand side with a green light on the stick. If I can change to the better looking one I will as I would assume all the parts are there, so a stick change should work. Shed some light into this issue, will it work?
Yes, the crusie light is built into the combination meter. I really don't understand why the dealer installed ones are aftermarket ones. It kind of makes me think that there is something more to this than we think...
Old 11-01-2008, 10:00 PM   #2
CB900F2
Drives: 08 Sedan
It does seem that way, but for all of the info on the OEM CC unit and the info all being OEM like the Service Manual, EPC, and confirmed wiring is there... and the confirmed 08 model with the enhanced power package comes with the OEM CC, it makes no sense to why the aftermarket unit was pushed as the dealer install option..
I have been searching the local wreckers to find a compatible CC switch which from all of the online Toyota OEM parts suppliers claims that 07+ Camry and many other models of cars use the same CC switch unit...
I will then purchase the wire harness once I have the switch and give it a shot (cross my fingers!).. Unless someone can beat me too it!
Old 11-01-2008, 11:09 PM   #3
b_hickman11
Drives: 08 Sedan
As I posted before, my 08 with power package has the same CC that was in my 05 Tacoma so more than likely all Toyota's CC for vehicles with the power package is the same(at least going back to 2005). My 07 does not have the power package but has the Rostra CC. This CC was not installed by the dealer. It was either installed by the distributor(the port) or was installed in Japan. The same exact Rostra CC that is on my 07 Yaris is the same one that is on my parents 2001 Tacoma. So Toyota has been using the same setup for at least 7 years.
I will take a look at my ECU number tomorrow and post them on here.
b_hickman11 is offline   Reply With Quote
Yaris.. Cruise Control. peanut New YARIS Purchase Forum 28 11-26-2017 06:17 AM
Cruise Control in the LB RobotMan In Car Entertainment + Electronics (audio / video / alarm) 1 09-30-2007 02:43 PM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
