![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Accessories for 5-door '09 LB?
Ok, so I was looking forward to installing my TYC tail lights on my new '09 5-door LB. Got one of the stock lights out and the TYC lights won't work. The tail light connector on the '09 5-door LB is different.
When can we expect to see some new tail lights for the '09 5-door LB? Same question for fog lights. The fog light shrouds on the '09 non-S LBs is different than the shrouds on previous model year LBs. |
can you take a picture of the new stock taillight connectors?
Is the shape of the taillight the same? Many people just wire up aftermarket lights by splicing the wires.
Hey Thomas, I wonder if they adopted the Thai spec for the harnesses? That would rock.
my thoughts exactly... most unlikely though!
But based on pictures, the actual physical shape of the light is the same, just the layout changes
The tail lights are the same shape as the '08 and '07 LBs' tail lights. Connector is different though.
I'll take pics. when I get a chance to. |
#6 | |
![]() Is the 08 tail light connector a six pin one row connector as opposed the the U-shaped connector of the 09? I ran into a pre-hack DIY on installing JDM lights on an 08 (which involved changing the connector on the car from the single row 6 to the U-shaped 6) and the pinout for my 09 is identical to the JDM lights shown in the DIY. |
If yours is an '09 5-door LB, then you have the same connector I do for the tail lights.
Oh, I don't know about the '08's tail light connector. I had an '07 LB and I know the tail light connector of the '07 LB is different than the '09 5-door LB's tail light connector.
The TYC tail lights I have, have connectors that match the connector on the '07 LB. |
#10 | |
I don't know. The TYC tail lights I have are boxed up and in the attic since I cant use them.
There are pics. somewhere here though. |
You could either change the male connector on the car (by popping the pins and moving them to the 07-08 style) or change the female connector on the TYC's to the 09 style. Both types use the same pins, so you would not have to cut and splice wires...
I wouldn't mind seeing a DIY about how to remove and and re-install those pins.
#14 | |
I could do that, but I want lights that follow the car's contours and curves. As you mentioned above, they would stick out on that part next to the hatch door that slopes inwards. |
#15 | |
http://www.yarisworld.com/forums/sho...DIY+Tail+light |
#16 |
![]() ![]() ![]() Drives: 2008 5-door Yaris Hatchback Join Date: Oct 2008
FYI... I run TYC tails on my 2008 hatchback.
#17 | |
![]() one photo you will see the back off the plug marked in red lines ,that is the pice you pop out ,then pull pins out the back of plug . Real easy , pay my airfares and i will fly over and show you ![]()
| The Official Toyota Thailand Accessories Order Thread | eTiMaGo | Items for Sale by private party | 417 | 11-23-2009 04:19 AM |
| LF: Yaris / Vitz / Echo hatch accessories / parts! | Keej_05RS | General Yaris / Vitz Discussion | 3 | 12-08-2008 09:43 PM |
| Toyota Accessories | GrassrootsMS | Cosmetic Modifications (Exterior/Interior) | 2 | 09-28-2007 12:21 PM |
| Official Toyota Thailand accessories for Yaris Hatch & Sedan | eTiMaGo | Cosmetic Modifications (Exterior/Interior) | 85 | 04-18-2007 07:53 AM |
| Canadian Toyota Dealerships with Yaris Accessories Online? | Violin | Canada | 49 | 04-11-2007 08:50 AM |
