Old 11-02-2008, 06:36 PM   #1
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Originally Posted by andries View Post
Therefore race- and rallycars have one. For more weight
Is not that the front strut bars don't do nothing... they just don't do nothing on a Yaris...
This is due to the chasis configuration of the Yaris.
Even if you are driving at the track...
You will have to install a full racing suspension in order to receive any benefit from a this bar on the Yaris.
There are a lot of other car that can use the benefit of a front strut bar even for street use. The Yaris is not one of those.
On the other side the rear sway bar does alot for the car.
I have not use the other under bracing available for the car... so I can not talk about those.
Old 11-10-2008, 12:22 PM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
To prove that you woulld have to put a strain guage on the brace to see what loading it is getting under side load - also you can statically load the lower wheel (with hydraulic/ratchet puller and come-a-long and see what moves. we'd do this for race setup - on the street just buy the part and feel the diff, if any. The car still def needs firmer bushings - the front wallows terribly on tight radius.
TheSilkySmooth is offline   Reply With Quote
Old 04-29-2009, 01:07 PM   #3
SEVEN
Drives: 07' HB Black
Does TRD springs and KYB shocks count as full racing suspension?? If not, just say that the STRUT BAR makes a lot of difference in the handling so I can sleep at night PLEASE
When life passes you by ... dowshift
SEVEN is offline   Reply With Quote
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 01:56 PM
**NEW ITEM** Tanabe Sustec Front strut bars C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 04-27-2007 09:54 PM
C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 01-10-2007 06:53 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Performance Modifications 2 10-07-2006 02:26 AM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM General Yaris / Vitz Discussion 3 08-30-2006 09:43 PM
