Old 11-02-2008, 11:37 PM   #1
b_hickman11
Drives: 08 Sedan
Originally Posted by CB900F2 View Post
I assume in the US, the PowerPackage is the package that came with the factory OEM CC switch that is built into the steering wheel as noted by Scotts parts diagram.. If so, yes...
b, you noted that you have a sedan with the power package and cc, do you mind checking your ECU part number?, it will be noted on the front of the ECU on a sticker..
thanks
89661-52G51 Power Package
89661-52F11 Non Power Package
Old 11-03-2008, 07:14 PM   #2
CB900F2
Drives: 08 Sedan
Thanks for the feedback...
My 08 Sedan has the same ECU as your 08 with the PP and OEM CC..
So, it looks like all of the planets are pretty much all lined up…
Confirmed ECU, Wiring is in place, Confirmed part#s…. Just need to try it now..
CB900F2 is offline   Reply With Quote
Yaris.. Cruise Control. peanut New YARIS Purchase Forum 28 11-26-2017 06:17 AM
Cruise Control in the LB RobotMan In Car Entertainment + Electronics (audio / video / alarm) 1 09-30-2007 02:43 PM
Rostra Cruise Control install done on MT AlexK DIY / Maintenance / Service 34 09-18-2007 03:21 PM
