Old 11-03-2008, 01:18 AM   #1
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
i got lucky...mine was a radio delete car...so...the second day of owning the car i had made my own mounting plate and was running a complete system.
BTW, was just wondering, if you are tossing 8" drivers in the door, im assuming you are modifying the plastic door cover...unless the hatches are much differant than the sedans or you found some very thin profile 8" woofers. my infinity referance drivers are 6" and using spacers only have half an inch clearance from my sedans door covers.
Old 11-03-2008, 07:55 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
4" mounting depth on my 8's... I'm not too concerned about them fitting. I might have to do some minor mods to the door panel... but hopefully I will not. It'll be closer either way. Right now HomeTheater is my main project. Weather is rainy here and I don't have a shop to work in, so spring or summer will be when I pick up on the car install.
