Old 12-17-2008, 05:48 AM   #1
ddongbap
I WOT it till I hit my desired speed, so this thing won't work for me.
What people REALLY need is an instant input thingy. A device that'll take away that smoother outer, which saves gas mileage. By doing so, you'd get near instant throttle response, similar to that of a cable system.
But like I said, it would demolish your gas mileage.
Old 12-17-2008, 06:55 AM   #2
N3misiS
N3misiS's Avatar
Drives: Yaris T1 1KRFE
Noogie,
You should tell me more about the S\C, I am doing the Rotex since it is the only one for my little car, what info do need, will this throttle plug in actually work or is it useless?
“Do or do not... there is no try.”
N3misiS is offline   Reply With Quote
Old 12-17-2008, 09:35 AM   #3
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Originally Posted by N3misiS View Post
Noogie,
Will your Rotex S/C run fulltime? The Blitz unit has a 4-position rotary switch that controls when the blower kicks in...Off, 25% throttle, 50% throttle, and 70% throttle. I was told by a Blitz employee that if you run the S/C fulltime, that you will not feel the effect of the Throttle Controller since you're boosting all the time.
If you are able to set your boost turn-on until the higher throttle settings, then the Throttle Controller will get you to boost sooner and make the transition smoother.
Old 12-17-2008, 07:17 AM   #4
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
thats what this unit is designed to do. give you more instant throttle response...and boy does it!
mikenacarato is offline   Reply With Quote
Old 12-17-2008, 09:37 AM   #5
LtNoogie
LtNoogie's Avatar
I'm glad you liked it. I was at the Blitz garage sale this weekend and almost bought the device but backed down since I have the alternative of boosting all the time.
I did, however, get a Blitz oil cap and radiator cap. Can't say I feel much more power as a result. Only poorer.
Old 12-17-2008, 09:28 AM   #6
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
hmmm.. sounds enticing.
Old 12-17-2008, 09:39 AM   #7
mikenacarato
SIPNDEW
Drives: 15 STI
i hope your not implying that the controller is functionless like the caps. if so your dead wrong.
Old 12-17-2008, 09:51 AM   #8
LtNoogie
LtNoogie's Avatar
No, not at all. I think the controller will give you a much better throttle feel. It has different settings right? It's supposed to reshape your throttle curve compared to the linear curve from the factory.
What I am curious about is how different does it feel from just flooring the pedal with the controller turned off?
Old 12-17-2008, 10:02 AM   #9
mikenacarato
SIPNDEW
Drives: 15 STI
it opens up quicker, half pedal is really full pedal with the controller on sp3. the best way to explain it imo is you dont get more power but you get your power quicker...if that makes sense. it really made my shifts into 2nd agressive because the throttle can open up quicker after the shift.
Old 12-17-2008, 10:04 AM   #10
LtNoogie
LtNoogie's Avatar
That's the way I understood it too. Enjoy.
Old 12-17-2008, 10:05 AM   #11
mikenacarato
SIPNDEW
Drives: 15 STI
supposedly the milder settings react very well with the supercharger.
Old 01-01-2009, 10:27 PM   #12
Klink10
Klink10's Avatar
Finished the install of the Blitz TC. Thanks to Mikenacarato for putting up with my questions. For the automatic IMO this is a must have. With a stronger throttle response there is no more need to use the auto shifter to get up to speed.
Old 01-02-2009, 01:33 AM   #13
mikenacarato
SIPNDEW
Drives: 15 STI
im glad you like it. :)
Old 01-02-2009, 04:22 PM   #14
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
what about the reverse process i heard ur suppose to turn this off during reverse or buy a special kit.
Old 01-02-2009, 04:23 PM   #15
mikenacarato
SIPNDEW
Drives: 15 STI
you can buy the cancel wire for an additional cost. i plan on doing it as soon as the blitz dealer here in nashville gets one in.
Old 01-02-2009, 04:41 PM   #16
Klink10
Klink10's Avatar
I got the reverse kit with mine, did not install it. It is easier for me just to ck the display at start up to ensure I'm at OFF or ECO before I put it in reverse. I have adopted a rule for myself to make sure to turn off when I shut it down.
Old 01-02-2009, 04:47 PM   #17
mikenacarato
SIPNDEW
Drives: 15 STI
it sets itself to off everytime you turn the car off anyways.
Old 01-03-2009, 12:36 PM   #18
Klink10
Klink10's Avatar
You're right, my bad....should have worded the above to say "check to be sure it's off".
Blitz s/c info cont'd cali yaris Forced Induction Forum 36 03-10-2009 12:33 AM
FS: $250 + Shipping - BRAND NEW Blitz R-FIT (Fuel Intensity Controller) Ran Kizama Items for Sale by private party 8 09-06-2007 04:26 PM
My Work, Your Work - Stories and Fun SmallCarGuy Off-topic / Other Cars / Everything else Discussions 0 09-02-2007 07:43 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
