Old 11-04-2008, 12:55 PM   #1
SilverGlow
Drives: 2007 Yaris Hatchback
Originally Posted by TheSilkySmooth View Post
Just as an example BMW M engines have been failing running our API SL, SM 10W-30. Also Chevrolet (corvette) pulled its mobil1 recommendaion and factory fill last year due to the oil NOT staying in viscosity grade throughout the OC service interval.
NO oil stays in viscosity during it's life.
ALL oils will eventually shear down in viscosity, and often this shearing is not much because oxidation of that oil can actually thicken the oil.
Spends some time at bobistheoilguy.com and learn how oil works...otherwise your opinions are based on nothing scientific.
SilverGlow is offline   Reply With Quote
Old 11-05-2008, 05:46 PM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Who do you think you are talking to? You have logical argument? You make me laugh so hard I bust my kidney, little boy - getting too big for your pants, little boy.
You have a speck of knowledge but not enough to be anywhere near expert in field of tribology. BITOG are rank amatures and full of misinformation. If you think this is good site you have been fooled. Spend seven years at University maybe you have some more knowledge.
TheSilkySmooth is offline   Reply With Quote
Old 11-05-2008, 07:19 PM   #3
PaidTimeOff
OMGWTFKITTYKATMEWMEWMEW
Drives: 2008 Yaris S
I had no idea spending seven years at a University grants one professional oil knowledge... I knew I should've stayed there two more years!
PaidTimeOff is offline   Reply With Quote
Old 11-07-2008, 11:44 AM   #4
SilverGlow
Little Girl, not once have you rebuttaled my posts with counter arguments.
Instead, you do what all people do who are ignorant, and who hate to admit stupidity, failure, and that's to character-assasinate the other person.
So go outside and drive the car your daddy or BF gave you, little girl...this site is for grownups.
Old 11-07-2008, 05:57 PM   #5
nemelek
DWEED
nemelek's Avatar
rebuttaled
Hey, SilverGlob. You are a whole lot smarter than me and perhaps the smartest member this forum has ever seen. Since you used the word you are the most qualified person I know to ask these questions. What is the meaning of the word rebuttaled?? What year did the Webster's dictionary add ed to the word rebuttal? I have heard of rebut, rebutted, rebuttal, rebutting, rebuttable, and rebutter but not rebuttaled. Your help would be greatly appreciated.
Old 11-11-2008, 12:18 PM   #6
TheSilkySmooth
Silverglow is a troll and should be ignored like most ignoramuses causing trouble and being of no benefit to the forum.
Old 11-11-2008, 01:31 PM   #7
1stToyota
1stToyota's Avatar
I think his advice on oil is bad. He throws "UOA" around a lot, maybe thinking it'll impress, but goes on to hand out advice about which oil to use, claiming that if 5w-20 is approved for use in our 1.5L, then "UOAs" will show that 0w-20 will work even better in our cars. Most people probably know better than to use a viscosity that isn't listed in the owner's manual or in the latest TSB, but SilverGlow doesn't seem to understand it yet.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 11-12-2008, 12:52 PM   #8
TheSilkySmooth
I agree, re: UOA are not everything. You can still have a massive failure due to inadequate viscosity which would NOT show up on a uoa until the rod is snapped in half or the had bearing seized and spun. And any mechanical engineer or engine machinist worth their salt will tell you noise = wear all else being equal (diesel are another matter). Also engine are designed to retard timing in the presence engine noise over a specific threshold. So thence goes the fuel milage with the water weight oils. I have dsriven fords designed to run on 20W oil and they run fine. I have never seen and engin that will run on a 20W or 30W. The piston to wallclearances are incompatible given most new engines employ slipper-skirt short pistons.
Old 03-21-2009, 10:03 PM   #9
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Rebutter
How about: rebutterable, rebuttering, or rebuttabler.
