Old 11-05-2008, 05:35 PM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Originally Posted by SilverGlow View Post
Not true again. The QS syn oil is great stuff and will not harm a Yaris motor.
As long as an oil's rating is SM, it is great oil and will provide all the protection a motor requires, REGARDLESS OF BRAND.
If you take the worse SM rated oil and use it in your Yaris, the engine will last just as long as if you used the most expensive special brand also at SM rating.
There is no better way to determine the goodness of an oil then a UOA.
Too much religion on oil brands....and often one's bias toward brand X is based purely on emotion, the cool purple color, etc and lacking any scientific data.
Buy the SM rated synthetic that is on sale regardless of brand and your motor will last 300,000+ miles.
Wrong Again - Do you need me to go through the SM spec line by line to show you where it is WORSE than SG? N.A. API oil is inadequate except in the most MILD driving conditions eg: moderate ambient climate, complete warm up, low rpm operation.
TheSilkySmooth is offline   Reply With Quote
Old 11-10-2008, 05:13 PM   #2
SilverGlow
Drives: 2007 Yaris Hatchback
The thousands of UOA's (used oil analysis) for SM rated oil call you a liar ;-)
SilverGlow is offline   Reply With Quote
How to Be a Street Racer - General Life Guide MDF Off-topic / Other Cars / Everything else Discussions 7 03-19-2007 12:49 PM
