Old 11-06-2008, 01:28 PM   #1
1stToyota
1stToyota's Avatar
Originally Posted by gid View Post
here's a concern , on T.S.B. ( http://www.automotiveforums.com/vbul...d.php?t=604802 ) for WARRANTY it states " NOT APPLICABLE TO WARRANTY " , does this mean TOYOTA is not responsible for the use of these oils in their engines ? Makes me wonder if they've done enough research and we are the lab rats . Many TOYOTA owners are having an issue with TOYOTA for the TACOMA frame that's rotting out and breaking . Especially for those who own the 2001 and 2002s , so my trust in TOYOTA is not 100% . Last , since the switch from 5w-30 > 5w-20 there's more engine noise , it's most noticeable at high speeds on the interstate . Seems like it could be the timing chain , . I'm considering to dump this fill of 5w-20 and go back to 5w-30 . The oil is PENNZOIL Platinum which is highly regarded at www.bobistheoilguy.com for U.O.A.s . If curious , http://www.bobistheoilguy.com/forums...Board=3&page=1 , there are other good U.O.A.s for the PLATINUM 5w-20 on other pages , so I doubt it's the oil .
They say to use 5w-20 that will void the warranty?
And also in the very same *updated* Toyota TSB they cover themselves again when saying it's okay to use 5w-20, but see the attached *note*...
Quote: "The recommended viscosity grade for this oil differs according to vehicle model. Use the recommended grade specified on the oil filler cap or in the Repair Manual or Owner’s Manual for each vehicle."
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 11-06-2008, 05:43 PM   #2
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Nope what it mean is that you can't go to Toyota and have change it under warranty. Which means you pay for the change! Also that our series engine has to be in the TSB for 5w20 which is 1NZ
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 11-06-2008, 06:28 PM   #3
1stToyota
1stToyota's Avatar
I don't know what free oil change claims has to do with this part of that Toyota TSB...
Looks like it's pretty plain to me: "Use the recommended grade specified on the oil filler cap or in the Repair Manual or Owner’s Manual for each vehicle."
2008 Scion xD
Old 11-06-2008, 09:51 PM   #4
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Exactly but in the TSB 5w20 is specified for the 1NZ so what there doing is "If you don't understand this just do what the cap says" That way Toyota never misguided you and washes their hands. So if you every have an issue remember TSB number or the Cap and your fine when your up against Toyota cuase they specified there options so both are OK
R-CaT
Project Yar 2ZR
Old 11-07-2008, 01:35 AM   #5
dallas
Drives: Yaris Hatch /Landrover D2
Wear metals in testing do go up for me with 5w20, best results with 0w30.
dallas is offline   Reply With Quote
Old 11-07-2008, 11:56 AM   #6
SilverGlow
Drives: 2007 Yaris Hatchback
Not true in every case, every climite, every season.
The wear numbers I get using 0w-20 versus 0w-30 are the same.
SilverGlow is offline   Reply With Quote
Old 11-07-2008, 12:40 PM   #7
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Sorry SGlow, you are loosing your argument. If You like oil so much maybe you can be YarisWorld mascot? This might be Good:
TheSilkySmooth is offline   Reply With Quote
Old 11-07-2008, 01:20 PM   #8
1stToyota
1stToyota's Avatar
Don't dispute his UOA, please.
2008 Scion xD
Old 03-21-2009, 10:52 PM   #9
dallas
Show me the Money, I mean results,LOL.
QUOTE=SilverGlow;167511]Not true in every case, every climite, every season.
The wear numbers I get using 0w-20 versus 0w-30 are the same.[/QUOTE]
Old 11-07-2008, 08:42 AM   #10
1stToyota
1stToyota's Avatar
Both are okay, if you don't mind the extra noise with 5w-20. To me extra noise = extra wear.
2008 Scion xD
Old 11-07-2008, 11:53 AM   #11
SilverGlow
Your opinions lack scientific bases, and you use "noise" to determine wear?
People that go to college and learn science know that actually using highly controlled and scientific tests, like a used oil analysis to ascertain wear is far more conclusive.
And if you use noise to decide, did you run your car in a sound studio, and monitor the noises with fined tuned computer monitors? Did you do before and after tests?
Did you graduate from highschool?
Old 11-07-2008, 01:29 PM   #12
1stToyota
1stToyota's Avatar
Genius, you're the guy that's using 0w-20 in southern Ca, eventho' the Toyota TSB says do NOT use 0w-20 in our 1.5Ls, under ANY condition. See how well your warranty works for you after you inform the service department that you refused to follow the Toyota TSB guidelines, not to mention your owner's manual, provided that you have any future issues with your motor.
2008 Scion xD
