Old 11-07-2008, 01:25 PM   #1
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
Originally Posted by metalshark View Post
I put the pictured intake on six months ago. I really like the improved midrange and top end performance. Based on its helmoltz frequency of resonance your short rams will perform better at high revs and give up some bottom end torque. The ebay unit is better designed than the stock box because the pipe is straight and long on both sides of the sensor. In theory the undistrubed flow should give a more linear consistent air mass signal to the ECM.
It is a pain to service the air filter inside the left front fender. I have 15K on the odometer and tomorrow I have to pull the filter and wash it, dry it, and recharge it with the K&N kit. With this intake and all my exhaust mods I can bang the little mill off the rev limiter quickly. This intake is much better for a straight stick than an auto. If you gotta have a brand name and color anodize go for it. When I put this on I never got a CEL. Some of the users that went with the fancier CAIs did temporarily get CELs until their ECMs could re-write the learning part of their epromms.
i agree but i have almost 30K
i had to flip the bumper back to get to the filter
same way on our TC too
Old 11-09-2008, 04:26 AM   #2
metalshark
MetalShark
Drives: 2008 Yaris LB
I had to pull the left front tire off and pull down the bottom plastic panel under the left front fender to get the air filter off for cleaning and recharging with the K&N shampoo and oil.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
EBay: Yaris Intake Manifold ChinoCharles Performance Modifications 21 10-22-2008 04:35 PM
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
