Old 11-07-2008, 05:57 PM   #1
nemelek
DWEED
nemelek's Avatar
Originally Posted by SilverGlow View Post
rebuttaled
Hey, SilverGlob. You are a whole lot smarter than me and perhaps the smartest member this forum has ever seen. Since you used the word you are the most qualified person I know to ask these questions. What is the meaning of the word rebuttaled?? What year did the Webster's dictionary add ed to the word rebuttal? I have heard of rebut, rebutted, rebuttal, rebutting, rebuttable, and rebutter but not rebuttaled. Your help would be greatly appreciated.
Old 11-11-2008, 12:18 PM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Silverglow is a troll and should be ignored like most ignoramuses causing trouble and being of no benefit to the forum.
TheSilkySmooth is offline   Reply With Quote
Old 11-11-2008, 01:31 PM   #3
1stToyota
1stToyota's Avatar
I think his advice on oil is bad. He throws "UOA" around a lot, maybe thinking it'll impress, but goes on to hand out advice about which oil to use, claiming that if 5w-20 is approved for use in our 1.5L, then "UOAs" will show that 0w-20 will work even better in our cars. Most people probably know better than to use a viscosity that isn't listed in the owner's manual or in the latest TSB, but SilverGlow doesn't seem to understand it yet.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 11-12-2008, 12:52 PM   #4
TheSilkySmooth
I agree, re: UOA are not everything. You can still have a massive failure due to inadequate viscosity which would NOT show up on a uoa until the rod is snapped in half or the had bearing seized and spun. And any mechanical engineer or engine machinist worth their salt will tell you noise = wear all else being equal (diesel are another matter). Also engine are designed to retard timing in the presence engine noise over a specific threshold. So thence goes the fuel milage with the water weight oils. I have dsriven fords designed to run on 20W oil and they run fine. I have never seen and engin that will run on a 20W or 30W. The piston to wallclearances are incompatible given most new engines employ slipper-skirt short pistons.
Old 03-21-2009, 10:03 PM   #5
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Rebutter
How about: rebutterable, rebuttering, or rebuttabler.
