The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
actually, time to recalculate. the 6x9 does have more surface area than a 6.5 oval. however, while
the driver surface is bigger allowing more air to be moved, it does not change the problem that all oval speakers suffer from...the fact that the driver is mis shaped effects sound quality especially when the speaker is being pushed hard. round speakers are ussually the way to go, but, you ussually get more bass "hit" out of a 6x9 than a 6 round on cheaper speakers because of the larger radiating surface...same with subs. a more expensive 8" sub may sound better than a cheaper 15", but odds are in pure bass, the 15 will hit harder. we do agree on one thing, that rear fill should be minimised, and its why I have always run them off of deck power and fader moved far forward. but, we disagree on another. I belive that while rear sound should be minimised, it does improve sound quality to have it there, but ambient. and I disagree on bass or midbass from the rear deck. if you have subs the impact is already slamming you from the rear, and you want midbass hitting you from the front...most midbass will be obliterated or drowned out in the back if you are runned anything decent or bigger than a couple 10 inch drivers. low bass is almost non directional, which is why subs cut off at 40 hertz or less work fine in the trunk, but the higher up the frequency, the more directional the sound. mid bass should be shifted as far forward as possible, to give the appearance of the "concert" you spoke of. cutting a midbass driver off at 1k will most likely fry it fast, and your sound quality will be very foul. at 300hz deeper vocals can be heard, and a mid bass driver playing above that will sound very muddy normally. also, at that point, your ear can easily pick up direction of the sound, so the whole point you made about making rear fill disappear is moot. I think you and I agree on some of the fundamentals of sound, but, we have entirely differant methods of getting it so it would seem! either way, I am not a expert by any means, and I base my opinions on my experiences and what others have said or i have read or seen.
#2 | |||||||
Audio Junky
SD = the effective radiating surface area (AKA Cone area) of a speaker. There aren't many 6x9's on the market that don't have a co-axial design which means a circle in the middle about the size of a 50cent piece is missing... which is a good portion of its cone area. On that site. the SD is listed as 22.8 (for some reason its in sq inches, normally SD is listed in sq cm or sq m) 22.8 square inch = 147.096 48 square centimeter compare that to a 6.5" speaker size (this is not a midbass, but a midbass would have a very similar sd) http://www.parts-express.com/pdf/264-852s.pdf which has 140sq cm Difference of 7sq cm. Nothing noticeable. Now, if you do find a 6x9 without a coaxial design... Tangband makes one. http://www.parts-express.com/pdf/264-837s.pdf then the SD will jump drastically to around 220sq cm. WHICH IS VERY SIGNIFICANT! Quote:
A well tuned system should not sound like subs are in the back seat.... even if they are. Quote:
Some people run midbass drivers higher than others.. .it all depends on the speaker chosen. I personally prefer a 250hz & lower limit. Quote:
I don't know everything... but I do know rear fill is a waste of money. |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
| Custom Catback System | Sabretooth | Performance Modifications | 48 | 07-10-2007 09:59 AM |
| Fiberglass enclosure / Stereo system | bugnuts | In Car Entertainment + Electronics (audio / video / alarm) | 30 | 05-20-2007 12:11 PM |
| Immobilize and security system. | Meow | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 04-18-2007 05:40 PM |
