Old 11-08-2008, 10:11 PM   #1
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Try removing the air conditioning air filter for a few days and see if that helps.
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Old 11-09-2008, 03:22 AM   #2
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Okay, found a little bit of semi-solid decaying leaf matter in my drain that smells like total shit. Looks like I've been carrying mulch around with me everywhere I go. Think I'll watch where I park from now on, and lay-off the A/C a little. Spraying Lysol in the vents once a week would be an added option. Thanks everybody for your advice
Old 11-09-2008, 03:44 PM   #3
captainm27
Drives: 2008 Sedan A/T Silver
Can you post a pic to see where exactly you are looking at? Thanks!
captainm27 is offline   Reply With Quote
Old 11-11-2008, 12:41 AM   #4
SilverBack
Joey
SilverBack's Avatar
Sorry can't put up a pic. Camera's dead, but feel free to take a look at yours and take a pic for everyone else here who also has this problem. Think they would appreciate it.
Old 11-24-2008, 02:05 PM   #5
mmxcix
Drives: 2008 Yaris
Sorry, Toyota or the dealership forgot to install a cabin air filter on mine. They must be cutting corners or QC#666 was taking a break and it missed mine in the production line.
mmxcix is offline   Reply With Quote
Old 11-25-2008, 11:48 PM   #6
SilverBack
Joey
SilverBack's Avatar
Why not just install one yourself?
Old 11-30-2008, 11:18 PM   #7
mmxcix
Drives: 2008 Yaris
That does not really fix the issue of the odor. A wet cabin filter cannot be the culprit when there isn't one installed. I already removed the glove compartment and removed the carpet on the passenger side just to see if there is any leak from the drain or any hoses and I can not find any. I already sprayed lysol (as suggested) on the vents but the odor is still there.
Plus it defeats the purpose of installing a cabin filter if I drive with the windows open just so I don't have to use the AC and increase fuel economy back when gasoline was $4+/gallon.
In any case, any other suggestions where the smell can be coming from. I sure hate to bring the car to the dealership as I know they would just tell me "we're not smelling anything". Any help would be much appreciated.
Old 12-01-2008, 03:36 PM   #8
Did you actually clear the condensate drain tube?
Old 12-05-2008, 09:57 AM   #9
mmxcix
Drives: 2008 Yaris
Yes I did that yesterday, I used a long thick plastic cable tie and inserted it in the drain tube and the drain seemed clean and clear. Just for good measure, I tested the cable tie I used for similar odor and there was non't any odor. Morever, it was also dry (that's because I have not used the AC that day because of the cooler weather) which meant that there isn't a stagnant water condensate in the tube. Oh yeah, I installed a cabin filter while I was at it ('should have gone back to the dealership and told them they sold me the car without the cabin filter installed).
This is really bugging me. I googled the issue and to my surprise it is not an uncommon problems with cars of any type. I may have to go to the dealership and deal with the inconvenience. *sigh. Why are dealership customer service only good when you're buying the car but it's the exact opposite when you're having your car fixed under warranty (at least from my experience)?
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 12:59 PM
Air Conditioner Noise & Leak? Dawn Eshelman DIY / Maintenance / Service 116 07-21-2015 01:22 PM
$7 Ram air intake pictorial turbodiesel Performance Modifications 19 10-27-2008 05:46 PM
air filter multipart btc50 DIY / Maintenance / Service 1 08-31-2007 06:37 PM
