Old 11-09-2008, 07:46 PM   #1
CaptainYaris
Drives: 2007 Toyota Yaris S
Wonderful walkthrough. Took it step-by-step on my 4 door and it worked perfectly. got the same system from Circuit City on sale. Not a bad upgrade for $50
CaptainYaris is offline   Reply With Quote
Old 11-10-2008, 05:19 PM   #2
b_hickman11
Drives: 08 Sedan
Hopefully nothings goes wrong with. Circuit City filed for bankruptcy today and are shutting down a lot of their stores. My local store is suppose to be shutting down by Jan 1.
b_hickman11 is offline   Reply With Quote
Old 11-12-2008, 01:48 PM   #3
CaptainYaris
Looks like i need to go back and tap into the green wire. another problem i was having is that when i turn on the car, all the doors go through the "unlock" cycle. hopefully this issue will be remedied by this as well.
Old 11-12-2008, 01:56 PM   #4
The unlock on start issue is probably a "programming option" for the keyless entry.
Old 11-13-2008, 08:28 AM   #5
CaptainYaris
I've looked through the programming guide and i think i'd have to disable the "lock on start" to disable the quick unlock on start. Its really not that big of a deal.
But the switch to the Green wire worked wonderfully, although i have to say the Valet system is a little slow to respond between the first press and the 2nd press, you have to wait for the parking lights to stop flashing before you press the button a 2nd time.
Old 11-13-2008, 08:31 AM   #6
Does the valet have a mode for double pulse of the unlock wire? My UltraStart did and it makes life a lot easier than having to press the remote twice.
Old 11-13-2008, 12:44 PM   #7
CaptainYaris
I'm not sure if it has a double pulse mechanism. that was actually the issue i was trying to avoid. i like being able to just unlock the driver side door.
Old 02-15-2009, 01:26 PM   #8
cdaddy626
Drives: 2009 Yaris
Keyless install
I would like to thank Dan for creating this great DIY, installed 712t yesterday on my 2009 with no problems. Only difference to note is D3 connector on my car has more than just a black wire, there are actually 3 other wires on this connector. Also had to completely un-bundle the wires going to the 20 pin connector because there are 2 brown wires, very easy to get confused on which one is the LOCK one. I would like to send a thanks to Scott for his help via PM's as well.
cdaddy626 is offline   Reply With Quote
keyless entry? / security? mem In Car Entertainment + Electronics (audio / video / alarm) 8 10-22-2008 01:29 AM
Keyless Entry BLKYRSSDN In Car Entertainment + Electronics (audio / video / alarm) 44 09-16-2007 10:27 PM
Aftermarket Keyless Entry - How does it affect the Warranty? aerock19 In Car Entertainment + Electronics (audio / video / alarm) 7 09-07-2007 02:11 PM
I want keyless entry!!! Lillydot General Yaris / Vitz Discussion 7 03-20-2007 10:46 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
