Old 11-10-2008, 10:28 AM   #1
gboezio
gboezio's Avatar
Drives: Yaris 4dr 2008
I read that some EPROM will erase themself if they are hacked in some way, I just hope it's not the case here.
If they do have encrypted their data, there's no way to decrypt unless we get the key, witch should be somewhere in the ECU.
Nothing is impossible, but this seem to be very hard to achieve.
We need more info on this EPROM, some spec sheet.
Originally Posted by Nexus1155 View Post
If i were trying to crack it through OBD, maybe, but ive dealt with encryption before on the Audi ECU's. When you are dealing with something that has direct contact with the MCU, i doubt there will be an encryption since it is such a mundane way of programming the ecu directly from the factory... Now if they removed a resistor to short out the communication, then ill be screwed...
A chat with a Toyota chief mechanic coud provide some good info on the "how" they reflash them, but it may be a simple hook the machine and press play...
If it's the way they change their maps, I guess it's possible to go trough there, the best tuners are all over the Supra, but I doubt that their ECU is as complex as this one.
gboezio is offline   Reply With Quote
Old 01-04-2009, 09:01 PM   #2
GeneW
Drives: 2008 Yaris
Probably a checksum that is computed at the time of code compilation. That was one way to do it.
If the checksum doesn't add up the code will not run.
Gene
is the yaris for me? sauruman New YARIS Purchase Forum 14 02-27-2006 08:27 PM
