Old 08-16-2013, 08:26 PM   #1
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
I sprayed lithium grease on the linkage with great result the squeak disappeared.
But is it a sign that there's something wrong with the linkage? Like it needs to be replaced? because it's worn or something etc.
My Yari is going great i'm happy to report it's an 07, 3-door hatch, 1.5 ltr engine.It's done 155 556 km and it's still going and keeps going. Touch wood!
I sprayed the linkage added red line mt 90 along with nulon gearbox treatment. I changed the plugs, air filter, oil filter and of course did regular engine oil changes using full synthetic.
Had wheel alignment and it's going well. I feel a bit of an improvement to the way it's running. Touch wood hoping it continues.
Next in line is front brake pad change :)
Old 08-21-2013, 04:11 PM   #2
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
Fixed my squeek with this as well.. first tried the silicone spray.. lasted about 2 weeks.. came back with lithium grease the second time.. been squeek free for a couple months now. :)
CueBall is offline   Reply With Quote
Old 08-21-2013, 10:07 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Yeah I was also using silicone for this, but it turns out that stuff only works while its viscosity is just right... After that it ends up making things worse, according to the mechanic.
Old 09-19-2013, 09:20 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Just take the drums off and clean the dust out. The squeak should go away.
Old 10-24-2013, 10:03 PM   #5
Nigel8600
Drives: 2008 Yaris Sedan
I also just oiled the yellow circled section and the problem went away immediately. When I had the car up on my ramps doing the gear oil I gave it an extra shot of spray from underneath too for extra luck. Unfortunately I used silicone spray because it was on sale for 2.50 a can and the white lithium grease spray was 8.99 lol.
Nigel8600 is offline   Reply With Quote
Old 11-02-2013, 01:29 AM   #6
Nigel8600
Soooo, for the record, my silicone spray lasted only 1 day per lube. I sprayed with white lithium that I had to go back to the store and buy 5 days ago and its still not squeaking. Don't waste your time with silicone spray.
Old 09-27-2014, 07:30 AM   #7
Dmonte
Drives: 2007 yaris sedan 4d
Does this also apply to automatic transmissions? Because my car has had a similar squeek for 3 months now ...
Dmonte is offline   Reply With Quote
Old 09-27-2014, 09:40 AM   #8
No. An automatic does not have the mechanism that this thread is discussing.
Old 02-18-2015, 07:58 AM   #9
pightzter
Drives: Vios 2014
hey guys i just registered. im from the philippines and got a 2014 vios which is sort of a sibling of the yaris. found this thread due to a squeak in shifting gears (manual). so anyway thanks to the thread starter my problem got a quick fix instead of lining up in the dealership. i used an ordinary oil lubricant with paintbrush and glazed the joints.
the cause of the squeak, as recalled, was by engine wash. some newbie overdid it using a pressure wash. so a tip out there for squeaking shift gears after an engine wash, the grease from the shift joints inside the engine bay must have absorbed some water and in the process pushed away some of the lunricants.
hope this reply helps.
super thanks to this thread!
pightzter is offline   Reply With Quote
Old 03-28-2015, 02:27 PM   #10
Mikastef
Drives: Yaris
Can this work in an automatic gearbox?
Mikastef is offline   Reply With Quote
Old 09-18-2017, 01:54 AM   #11
komichal
Is this engine-dependent?
My Yaris 2007 uses 2SZ-FE engine and I am not able to find this part in the engine compartment...
Old 03-28-2015, 10:28 PM   #12
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
No, the auto gearbox does not have the clutch lever. Must be something else.
Old 09-18-2015, 11:58 PM   #13
xdarkxfirex
Drives: 2015 yaris le
What about the automatic? I get a squeaking sound shifting into d or taking off most times
xdarkxfirex is offline   Reply With Quote
Old 09-19-2015, 09:33 AM   #14
Bluevitz-rs
could be a bad motor mount
Old 11-18-2015, 04:59 PM   #15
esse10
Drives: 2009 yaris 2 door
squeak
Anybody figure out how to lube the inside of the Clutch release fork boot pivot point? blue arrow in this picture.
File Type: png toyota-yaris-clutch-parts-components.png (36.9 KB, 300 views)
Old 07-13-2022, 07:59 AM   #16
esse10
squeak noise no more
I just recently replaced my Clutch/pressure plate/throw-bearing ........and in fact i replaced the whole transmission gear box in my car. The squeak is coming from the fork pivot point and also the throw-bearing when it pushes the fingers of the pressure plate. Just put a little coating of grease on those parts and ........problem solved- NO MORE SQUEAK.
Old 11-18-2015, 05:02 PM   #17
tmontague
tmontague's Avatar
I just stuck a straw in there from a can of lithium grease and sprayed. I also sprayed it on all the shift linkages on top of the transmission. My squeak went away and has been for a couple months now.
FWIW I had a squeak when i'd depress the clutch pedal
Old 11-18-2015, 06:23 PM   #18
esse10
ok
oh okay, I was skeptical about doing that cause you don't want to spray the clutch disc or something that'll cause more harm or start slipping. I was thinking if maybe I can get a camera probe in there to see what specific parts to lube or not.
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
