The unlock on start issue is probably a "programming option" for the keyless entry.
#2 | |
![]() Drives: 2007 Toyota Yaris S Join Date: Aug 2007
But the switch to the Green wire worked wonderfully, although i have to say the Valet system is a little slow to respond between the first press and the 2nd press, you have to wait for the parking lights to stop flashing before you press the button a 2nd time. |
#3 | |
I'm not sure if it has a double pulse mechanism. that was actually the issue i was trying to avoid. i like being able to just unlock the driver side door.
Bacon!
Drives: 2008 Red Yaris LB Join Date: Oct 2008
Thanks Dan!
Installed mine this afternoon using Dan's DIY instructions and the info. from this thread.
It was a lot less intimidating once I removed the unused wires from the 712's wiring harness. I decided not to hook up the horn wire since I leave for work at 3:30 in the morning. ![]() So far I like the ignition controlled locking, but I think I might turn off the ignition controlled unlock. The unlocking seems like a safety hazard to me. I turned on the double pulse for remote unlocking so all three doors unlock at once. I like to throw my backpack in the hatch when I leave the house and this makes it easy. All said and done it was much easier than I thought it would be, now I need to order some foglights. |
![]() Drives: 2009 Yaris Join Date: Feb 2009
Keyless install
I would like to thank Dan for creating this great DIY, installed 712t yesterday on my 2009 with no problems. Only difference to note is D3 connector on my car has more than just a black wire, there are actually 3 other wires on this connector. Also had to completely un-bundle the wires going to the 20 pin connector because there are 2 brown wires, very easy to get confused on which one is the LOCK one. I would like to send a thanks to Scott for his help via PM's as well.
Unlock all doors
I was trying to get this to unlock all 4 doors and hatch with one press of the un-lock but I have to press it multiple times. I programmed for double pulse unlock but that doesn't work. Any ideas? Install was on 2009 and conducted exactly as per the DIY. Thanks....
#8 | |
I programmed my UltraStart to do the double unlock and when I press the unlock button on the remote I hear the front door click, then about a second later, the other three and the hatch click. |
#9 | |
Unlock all doors
| keyless entry? / security? | mem | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 10-22-2008 01:29 AM |
| Keyless Entry | BLKYRSSDN | In Car Entertainment + Electronics (audio / video / alarm) | 44 | 09-16-2007 10:27 PM |
| Aftermarket Keyless Entry - How does it affect the Warranty? | aerock19 | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 09-07-2007 02:11 PM |
| I want keyless entry!!! | Lillydot | General Yaris / Vitz Discussion | 7 | 03-20-2007 10:46 PM |
| DIY KEYLESS ENTRY on Power Liftback? | TC-LIFTBACK | DIY / Maintenance / Service | 0 | 08-23-2006 09:57 AM |
