Old 11-16-2008, 03:24 AM   #1
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
unless one has a serious hookup, you will not be seeing prices like the ones above.. change $150 for piping/flange/mounting brackets to about $500 for a more accurate number. and don't forget engine management.
trust me, DIY turbo will cost you less
Old 11-16-2008, 10:10 AM   #2
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
wow, so technically as the cost of living goes up, pay gets cut and layoffs, and we get screwed even more... very nice
Regardless I cannot use engine management as of now anyways so i'm going to wing it without it until i find a better method than is out there now.....and pricing just depends where you shop until you find a good price...
I think the mounting brackets would have been cheaper than most things, its just a piece of metal that you could possibly make yourself with rough measurements..
If i were to do turbo(Already have two spare K03's), id just rather buy richards kit anyways for it being the easier thing to do, the supercharger kit requires no welding, and the ARC welder i have sucks and spatter will go everywhere... Plus a supercharged yaris just seems right for some reason...
Old 11-16-2008, 11:31 AM   #3
dacourier
dacourier's Avatar
Drives: Black Sand Lift Back
Plus a supercharged yaris just seems right for some reason...[/QUOTE]Hell yeah
Clinging to my guns and religion down here in the south. Come and take them!
dacourier is offline   Reply With Quote
Old 11-16-2008, 01:17 PM   #4
Tamago
Tamago's Avatar
Drives: ZZW30
rough measurements are for horseshoes and hand grenades..
getting your pulley to line up perfectly will be an issue, and making a bracket strong enough will be difficult without aluminum..
Old 11-16-2008, 10:50 AM   #5
there is indeed something indescribable about the urgency of that whine
Old 11-16-2008, 12:46 PM   #6
Nexus1155
Drives: Audi
bahhhh that jackass that was selling the supercharger for cheap took it offline, what an asshat...kind of pissed right now, trying to see if i can find another deal...
Old 11-18-2008, 03:30 PM   #7
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I'm halfway through a Biltz installation right now and the engine compartment is getting very crowded. As Richard said, whatever you throw together had better make sure all your pulleys are lined up and parallel.
From the picture in the original post, you might need to cut a hole in your hood cause that sucker is big!
Like largeorangefont said, you need to build a new intake manifold or get Richard to make you one.
I don't know what are the major cost drivers in a complete supercharger kit but the compressor is only a part of it.
Old 11-18-2008, 04:13 PM   #8
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
DO IT DO IT !
id3379 is offline   Reply With Quote
Old 11-18-2008, 08:13 PM   #9
Nexus1155
Drives: Audi
Thanks for the advice Richard, and its good to hear the MAF would be able to handle it...
I will not be making a new intake manifold just utilizing the stock one with a connecting pipe, the air does not need to be direct as it still holds the same pressure charge.... with an intercooler, it will cut down on bends in the pipe work...
but you are right, the mounting will take alot of work if not the most... I have my cardboard and scissor ready ;)
But i still have a couple of recirc valves from an S4 and a small intercooler to boot
This is pretty much what it will look like, might be ghetto, but a supercharger setup that is cheap, would you argue?
Old 11-18-2008, 09:17 PM   #10
richardholdener
Drives: 2008 Yaris hatch
I love this home made stuff-you should see my compound turbo system on my 1987 Sprint-full Mad Max style.
richardholdener is offline   Reply With Quote
Old 11-18-2008, 09:26 PM   #11
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
whats the part number off of that supercharger. im going to see what my cost is on it.
mikenacarato is offline   Reply With Quote
Old 11-18-2008, 09:49 PM   #12
Nexus1155
Drives: Audi
It is an Eaton M45, P/n 117159-10,7526657-01 ....surprised i found that... Got any pics of the Turbo Sprint Richard?
No pics means it didn't happen ;) I would love to see it though
Old 11-18-2008, 10:12 PM   #13
Tamago
Tamago's Avatar
Drives: ZZW30
a turbocharger can be had for $50
a cast manifold for $180
but hey, good luck ;)
Old 11-18-2008, 11:30 PM   #14
Nexus1155
Drives: Audi
turboing just has more knitpicky parts :-/ thats the only reason im not doing it...
but supercharger, ohh man...
Woooooooo....Woooooooooo...WOOOOOOOOOO
Old 11-19-2008, 08:10 AM   #15
Tamago
Tamago's Avatar
Drives: ZZW30
be specific.. what nitpicky parts?
Old 11-19-2008, 02:44 AM   #16
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
If you do this your my hero.
ztrack157 is offline   Reply With Quote
Old 11-19-2008, 10:01 AM   #17
Nexus1155
Drives: Audi
oil lines/coolant lines/AN Fittings/Having to tape the block/pan/Wastegates/Boost Controllers/Intercooler/ More Custom Pipe work/etc....
Supercharging is based off the intake side, which means i do not need to do pipework, just making flanges with pipes.
There is a perfectly substitutable flex pipe in the marine world that holds up to70psi of boost and has good flow. Albeit it being Orange(maybe wrap it with electrical tape or some crap, variety of colors now), it is still somewhat pricey, but i think it will save tons on costs versus piping. If it could withstand the hotside of a turbo, i would've did that, but almost all silicone/rubber melts at those degrees...
And it is not like i am trying to build a monster here, the supercharger with a reduced pulley can make some good power... If i were trying to make a drag monster/track warrior... I would not keep this engine at all unless i had about 10k to throw into internals...
Old 11-19-2008, 10:24 AM   #18
Tamago
Tamago's Avatar
Drives: ZZW30
oil lines:
you tee into the oil pressure sensor already tapped at the block.
no one says you have to use AN fittings ;)
you don't have to tap the oil pan, use a sandwich adaptor. run the oil coming out of the turbo into your oil cooler and back into the engine
turbo:
you won't need a wastegate as most small turbos are internally gated
which also means you don't need a boost controller
you don't need an intercooler on low boost applications
and believe me, piping is much easier to fab than a bracket with "rough measurements" to hold a supercharger spinning 4X engine speed.
you can use that silicon exhaust hose for the charge air coming out of a turbo too ;)
