Are my trd springs installed upside down?
So if you have read my other posts i been having a lot of noise with my springs. Looking at other pictures of other members i think mine may be upside down. Do the tightly coiled springs supose to be facing up or facing down?
super duper M*******TOR
Drives: 2007 jahPANIS egg(Sarao Phil) Join Date: Oct 2008
any pics?
lol i did the same thing you talkng about the back ones right? The ones that are close together are suppose to be up to the chassi(sp) but it shouldnt make a diff as long as its the same diameter as top and bottom. Mine is upside down too ;) no problems
![]() ![]() ![]() Drives: Blazing Blue Liftback Join Date: Oct 2008
There actually is a difference in the ride with the springs upside down.
There was a pretty long thread about this before the hack. |
Beast
So that means.... Fix em you guys =D
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#6 | |
Break'em off some.
The ride height could be slightly changed if they are flipped or clocked differently, but they do not magicly change spring rate if upside down. |
Beast
Yeah but just so it doesnt bother you inside thinking about it because you will be paranoid about it... fix it <3 pics pics pics
Break'em off some.
the one thing that might make a difference is if the end of the coil is not facing the same way as the other, i.e both facing < <.
Break'em off some.
Yes, if they are clocked wrong, it could affect ride height, depending on how much the car is lowered, and how you have your spring isolators configured.
Hmm looks like mine are installed right =)
One thing i noticed though is they are not vertically strait it looks like. Kinda like a half moon bend in them. But i am sure i had them installed facing together the same way as the oem ones when i took them out. ANd put the spring insolators on the same way. Is this normal orsomething i should be concerned about. |
Break'em off some.
As long as they are on the spring perches.. there is nothing to worry about.
dont worry if its installed wrong but if will easy your mine you can jack you car up again and do it all over...i kno i wont forget that lol
| tanabe nf210 vs. TRD lowering springs?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 01-23-2012 11:00 PM |
| TRD OR Eibach...i'm confused... | hoahmaru | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 39 | 11-07-2008 08:25 PM |
| Installed TRD Quickshifter...thumbs up! | facebreaker1212 | Performance Modifications | 13 | 11-04-2008 11:20 AM |
| Question about 2 kinds of TRD springs & rear strut bar | Astroman | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-18-2007 05:44 PM |
| HOLEY COW 674.75 to install TRD lowering springs | dbaxter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 08-09-2006 12:40 PM |
