Old 11-17-2008, 06:26 PM   #1
Return of the Yarii
Drives: 2007 Sedan S
I have an 07 Sedan and mine was crossthreaded, found out when I did DC header install, bought a new one from Ken @ Sparks. Its listed in the classifieds along w/the header.
It is indeed an Air/Fuel Sensor, the O2 sensor is downstream
*pending sale of A/F Sensor to member on the board*
Return of the Yarii is offline   Reply With Quote
Old 11-18-2008, 08:24 AM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
The is all just a matter of semantics but these sensors conduct OXYGEN at various mixtures outputting a voltage in response to the mixture, so the sensor ONLY senses oxygen but the EC can calculate the mixture using E and a couple other variables for cross check. There is no FUEL sensor on a car per se. You have the MAF that indirectly "supposes" air flow through the "cooling" effect of ambient air running over a hot wire "conductor" or foil and adjust voltage across to run in stasis, and MAP that supposes "throttle position" by the reading absolute pressure in the intake manifold typically with a mechanical device sim to a "barometer". Toyota service parts can call it what they want, but the engineers that design it call it a wide band o2 sensor that looks at free oxygen in the pre-catalysis effluent stream. So maybe we call it #1?
Last edited by TheSilkySmooth; 11-18-2008 at 08:29 AM. Reason: duh, kant schpeil 2 gud?
1.3 Ltr Yaris Air Filter mods aucorium Performance Modifications 9 08-18-2006 08:32 AM
Need LA Yaris liftback Owners for Yaris Commercial weinsteins General Yaris / Vitz Discussion 10 05-04-2006 04:42 PM
