Old 11-17-2008, 09:06 PM   #1
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
Anyone think that the Sylvania Silverstars rated at 13.2 volts is going to be the source of this problem? I never had this problem until I installed these bulbs..
I have these same bulbs in my CRX for about a year now, with a 300 watt system.. never had a problem. As for the Yaris, I am now worried about burning my harnesses (for the bulbs) and the constant fuse replacing for the amps ):
Sponsored by: Micro Image
http://microimageonline.com
Old 11-17-2008, 09:11 PM   #2
What is the current rating of the Silverstars? The voltage rating is fine. Also, the radio and lights are on different fused circuits, so it shouldn't be an issue (unless the bulbs are drawing enough current to cause the battery voltage to sag enough to cause the amp to draw more current than its fuse is rated for...
